09 Street Bob riser problem....
Old Sep 18, 2009 | 11:59 AM
cbrittingham's Avatar
cbrittingham
Angry 09 Street Bob riser problem....
So if anyone has a solution to this problem please let me know....
I am trying to put some new bars on my 09 street bob. I take the old bars off and go to put the new ones on and they are touching the top of the fork brackets. I figure, well this is easy I'll just buy some risers and problem solved. Not in the slightest....
The top fork bracket has the grooves for the bars molded in the fork bracket and all the risers that harley sells (that I saw) wouldn't work. So does anyone have a solution to add just a fraction of an inch to the bars so they clear the top of the forks? Thanks for the help fellas.....
Old Sep 18, 2009 | 12:03 PM
bberck's Avatar
bberck
These will raise them more than you may want but they may make you some shorter ones.
https://www.hdforums.com/forum/dyna-...om-risers.html
Old Sep 18, 2009 | 12:37 PM
SBRob's Avatar
SBRob
FWIW, I think Loner Industries also has a 1" riser available as well, if the 2" shown in the pics are too much.
Old Sep 18, 2009 | 01:18 PM
powerlab's Avatar
powerlab
Doesnt it blow what they did to that triple tree...they say for streight...i say to save money!Eather way it sucks!
Old Sep 18, 2009 | 02:05 PM
Brad Groux's Avatar
Brad Groux
Yeah, I had to same problem as I wanted to go with drag bars so I had to buy a new "Triple Tree Upper Clamp." You can see my original post HERE. The Upper Clamp is $349.99 MSRP, part number is 45538-08... I purchased mine from Zanotti for $231.65. So that may be an option for ya.
Old Sep 18, 2009 | 02:09 PM
Bobbed Out's Avatar
Bobbed Out
Jshull had a few upper triples for sale for $265
harley doesn't sell them individually any longer so they're like $550 almost for a set
check with him and see if he's still got a direct line on those things
Old Sep 18, 2009 | 02:14 PM
SBRob's Avatar
SBRob
Yea, it sucks big time...I don't know how it saves 'em any money when they already have the top tree for the '07 model, but it really limits the type of handlebars without changing the top tree.
Oh well, rant over. lol
I love my Street Bob...
Old Sep 18, 2009 | 02:27 PM
powerlab's Avatar
powerlab
v-twin also sells just the top triple tree...thats were i got mine.
Old Sep 18, 2009 | 03:13 PM
CRF's Avatar
CRF
If you dont want to spend a couple of hundred $ on new triple trees you can just loosen the fork tube clamps on your trees and slide the fork tubes down in the trees a tiny bit (like a 1/8 inch)......that should give you the room you need to mount up the new bars - problem solved.
Either that or buy the 1" riser extension from Loner but that may not give you the look you are after - I have the Loner 2" extension and it works perfect for me but it does give you a bit of pullback due to the angle of the integrated riser on the top tree....
Old Sep 18, 2009 | 03:23 PM
cbrittingham
Alright well I appreciate the suggestions but I don't want to replace the trees... Does anyone have the link for Loner Industries??
