Mini ape to t-bar question
Old Sep 26, 2009 | 11:05 AM
krazhik's Avatar
krazhik
Default Mini ape to t-bar question
Hey for anyone out there that has gone from street bob mini apes to t-bar's I have a question about cable length. The new bars I ordered today have 8" riser's/32"width and 6" pullback. Has anyone made a similar switch and if so did you need to change cables?? Thanks for any help
Old Sep 26, 2009 | 12:07 PM
redrubicon2004's Avatar
redrubicon2004
I did it on my 03 wide glide. I think the stock bars are similar. My cables are slightly long now, but not too bad.
Old Sep 26, 2009 | 01:00 PM
thedonthere's Avatar
thedonthere
I went from the stock mini apes to night train drags with the 8" risers.Should be about the same length as what you're wanting to do. I used all the night train cables and they fit perfectly. You should be able to look up the lengths of the NT cables and go from there.
Old Sep 26, 2009 | 03:48 PM
nevil's Avatar
nevil
My first bar replacement was taking off the mini apes and installing with 8" t-bars from Wild 1. No problems except the turn sigs barely cleared the tank. Just relocated the sigs but I should have done that months ago. As long as you're changing bars you might want to think about doing it at the same time, it will make the bars look better, IMO.
Old Sep 26, 2009 | 04:45 PM
krazhik's Avatar
krazhik
Hey thanks for the responces. Sounds like I will be able to go ahead and use my cable's which should make things easier. And NEVIL I was already planning on a turn sugnal relocation, just trying to figure out what kit I will use or if I will just stick with the relocation in the UNDER 50$ MODS section. Thanks again
Old Sep 26, 2009 | 04:58 PM
nevil's Avatar
nevil
The kit I used was a Drag Specialties part that I got from Dennis Kirk for $19.95 plus like $8 shipping. It's clean and simple and doesn't stick out too far. Others have used the mod using another turn signal mount for the signal housing. (I would give you the part # but my regular computer just blew up.) Either way, you're under $50.
Old Sep 26, 2009 | 07:18 PM
lhcstreetbob's Avatar
lhcstreetbob
i went to 14inch t bars and didnt have to change any cables you should be good i also has enough to internally wire them..
slim12
Mar 19, 2013 09:50 PM
SSMNightTrain
Jun 2, 2012 07:47 PM
SGTGunner
Oct 15, 2010 11:23 PM
mstng5point0
Sep 29, 2008 11:03 PM
Subvamp
Mar 28, 2008 09:30 AM
