Pre drilled handlebars
Old Oct 11, 2009 | 02:27 PM
rocknrick's Avatar
rocknrick
SC-Longhair posted a video on how to take molex connectors apart for wiring. Mudd posted directions with pics on how to make a tool and use it to disconnect the wires from the connector. Both are great posts. You do not have to take the fuel line off from under the tank as there is room to remove the plug from above it - but if you are not patient, it may not be a bad idea. Good luck!
Old Oct 15, 2009 | 10:48 AM
Wonkaboy's Avatar
Wonkaboy
Thumbs up Thanks
Thank you but I'm going with a different set up now and i think the new bars aren't predrilled but i can still check out his video...
Old Oct 15, 2009 | 08:00 PM
Streets of Fire's Avatar
Streets of Fire
drill em out if they are not predrilled
Old Oct 16, 2009 | 01:01 AM
Wonkaboy's Avatar
Wonkaboy
Red face Drill
Yea i have to check it out when they come in next week !
Regards, Wonka
Old Oct 16, 2009 | 01:11 AM
Wonkaboy's Avatar
Wonkaboy
New Photo test
Old Oct 16, 2009 | 10:03 AM
r00k's Avatar
r00k
Originally Posted by cbz1200n
Do a search on taking the connectors apart, I think Mudpuddle posted on how to take them a part. Dis-connect the fuel line at the gas tank or you are likely to break it!
CB
Been there done that, the t-shirt is soaked in gas.
Old Oct 18, 2009 | 09:00 PM
Tuffstang's Avatar
Tuffstang
Default bars
What bars did you get? Gloss or flat Black? I'm having a set of stock 09 SB bars powder coated but can't decide on finish. Then running the wires internally.
Old Oct 19, 2009 | 06:59 AM
Wonkaboy's Avatar
Wonkaboy
Default New Bars
I am going with Night rod special bars Satin Black finish with 6-8 inch risers ..
Old Oct 19, 2009 | 07:06 AM
glideridemike's Avatar
glideridemike
If you can run the wires inside the bars it really makes for a clean look. Pre drilled are best, but drilling and de burring the holes works too. Just make sure when taking any connector apart that you mark the connector which wires goes back in where. Very fine tipped markers work best for that.
Good luck
Old Oct 19, 2009 | 09:55 AM
Wonkaboy's Avatar
Wonkaboy
Thumbs up Drill
Good luck
Thanks i'm going see what i can do ..
rs87277
Mar 29, 2022 04:46 PM
Cozz
May 28, 2018 03:06 PM
JamieDTR
Oct 3, 2014 12:27 PM
easyonmenow
Aug 29, 2009 12:55 AM
fatboyfrankster
Apr 28, 2007 06:53 AM
