Ohlins shocks price/performance ratio?
Old Oct 12, 2009 | 07:00 PM
yso191's Avatar
yso191
Default Ohlins shocks price/performance ratio?
My current phase for improvements to the bike is in the area of suspension & handling.
I have recently put on a Superbrace ($180), and just ordered a True-track ($300). My next purchase is Ricor Intiminators ($300).
The question is about Ohlins shocks. Are they really worth the price? It will take me 3-4 months to save the $$ for them, and I just want to know if the improvement is worth the cost. If I get them they will be the most expensive part of this project. If they make as much difference as I expect the True-Track & Intiminators to make they may be worth it, but if they make less of a difference, I think I'll pass and start saving for some engine performance stuff.
Thoughts?
Steve
Old Oct 12, 2009 | 07:12 PM
maddghost's Avatar
maddghost
I can't comment on ohlin shocks but Did you see this thread earlier today?
https://www.hdforums.com/forum/dyna-...uspension.html
Old Oct 12, 2009 | 08:38 PM
Vinsil's Avatar
Vinsil
Suspension is just one area to NOT try and skimp on. I say if you can, go for it. Look at other companies too, I see Works being brought up quite a bit.
I've rode offroad for a long time and have felt the difference in stock/aftermarket suspensions and shocks. WOW is all I can say.
If I could afford it, I would not only replace my rear shocks with some top quality built/tuned to me, but the front forks as well. But, I'm happy just cruising along anymore and really...the factory suspension is working good. For me.
Old Oct 13, 2009 | 08:39 AM
rounder's Avatar
rounder
get the Ohlins before the true track.
Old Oct 13, 2009 | 09:18 AM
GeorgeJ's Avatar
GeorgeJ
Rounder are you still running with the FXDX shocks.? I just picked up a set (poor mans upgrade) for my FXD and was wondering how much of an improvement they are over the stock chromeees.
Thanks - George
Old Oct 13, 2009 | 12:37 PM
yso191's Avatar
yso191
Already pulled the trigger on 'em. But I get your point.
Steve
Old Oct 13, 2009 | 02:54 PM
cornishman's Avatar
cornishman
An upgrade in shocks is definitely worth it. If i could have afforded the Ohlins i would have gone with them. As my pocket was,nt quite deep enough i went with what i could afford ( Hagons ). In my humble opinion a 96" with the sort of engine improvements such as yours and the right chassis improvements that you are doing / proposing will be a formidable tool.
Old Oct 13, 2009 | 02:57 PM
cornishman's Avatar
cornishman
By the way, i notice you have the Boyeson x- wing fitted. What is your opinion on it as i read a good write up on it in one of the mags.
Old Oct 13, 2009 | 03:39 PM
yso191's Avatar
yso191
The short answer is I don't know. I probably read the same article, and was interested. Boyeson has a good reputation and I know that with air flow small things sometimes make a big difference. For example head work: you want the intake ports roughed up to cause turbulence/mixing, and the exhaust polished to speed exhaust pulses. I wouldn't think those small differences would matter at all, but apparently they do.
I figured for the $100 they wanted off of ebay, it was worth the gamble. Even though I've read many a post on HDForums that they are snake oil, I didn't want to go through the expense of doing a dyno run pre-install, and another post, just to satisfy a naysayer, who probably wouldn't be convinced anyway.
But I am happy with the whole stage 1, I got good numbers: 90.6 Tq/76.36Hp. You can see my dyno sheet in my picture album if you're interested.
Steve
Old Oct 13, 2009 | 04:00 PM
cornishman's Avatar
cornishman
Steve
Thanks, like you the Boyeson name got my attention. I had them in myYam LC 350 as a lot of folks did..... jeez i can almost smell the two stoke.....wish i kept that bike .... oh and the Ducati 900 ss...... and on.... and on..
Id.Fat Bob
Aug 20, 2013 08:03 PM
sroc3
Jun 24, 2013 09:15 AM
RLJ
Mar 19, 2013 01:49 PM
AlanStansbery
Mar 14, 2013 08:33 PM
dp2826
May 17, 2010 07:51 AM
