***dyna models metric sizes database***
Old Jan 3, 2015 | 04:02 PM
  #41
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Originally Posted by robbyville
These have been listed already with previous years but FWIW 2014 FXDB continues the trend of:
10mm hex bolts on the clutch spring retaining plate
35 mm fork cap
Thanks, info added!
Old Apr 14, 2018 | 02:32 PM
  #42
FXD2003Rider
Refreshed some broken image links...
Old Dec 16, 2019 | 10:37 PM
  #43
99-FXDWG's Avatar
99-FXDWG
Stage III
Checked my '99 Wide Glide and it too is 17 mm.
Old Dec 16, 2019 | 10:47 PM
  #44
99-FXDWG's Avatar
99-FXDWG
Stage III
Rene',
Battery bolts on my '99 FXDWG are M6 x 16 but the heads are serrated flange, with an 8mm across-the-flats hex. The bolt head also has the ability to use a #2 Phillips screwdriver. When I installed a new battery, I transferred these bolts to retain the ability to "wrench" these bolts using either tool. The new battery was supplied with conventional 10mm across-the-flats hex bolts, but I like the original bolts better. Not sure if there is a H-D part number for the flange bolts I have.
Greg
Old Dec 17, 2019 | 09:43 AM
  #45
FXD2003Rider
Originally Posted by 99-FXDWG
Rene',
Greg
Greg,
The bolt you described is named BOLT, FLANGE HEAD and has p/n 4312C
Old Apr 25, 2020 | 04:45 AM
  #46
FXD2003Rider
New addition:
2007 FXDB (and several other years/models)
Nut, mainshaft p/n 37496-90A............................................... ............30mm 6-point socket (left handed!) (added 04-25-2020)
Old Mar 6, 2022 | 05:06 AM
  #47
FXD2003Rider
New addition:
2017 FXDB fork tube (l&r) damper (socket head) screw p/n 46614-06 ....................... 12mm 6-point socket head bit
contribution of multihdrdr
Old Mar 6, 2022 | 11:10 AM
  #48
multihdrdr's Avatar
multihdrdr
To be clear ... in above Post# 47, it is a 14mm bolt (shcs) needing a 12mm Hex Bit
Likewise the above bolt in Post# 40 is a 8mm bolt (shcs) needing a 6mm (M6) Hex Bit ... NOT M8
Working on my FXD '03 replacing the fork tube seals I noticed the fork damper screw needs an extended M8 hex socket wrench:
Note by FXD2003Rider:
Info provided by multihdrdr processed!
Old Mar 6, 2022 | 02:36 PM
  #49
FXD2003Rider
Wrench/bit sizes adjusted!
Thanks for the heads-up multihdrdr!
Old Mar 8, 2022 | 07:49 AM
  #50
snake_eyes's Avatar
snake_eyes
This is a great thread but it needs to be a sticky! I don't know how anyone would ever find it otherwise.
