WideGlide Conversion Underway!
Old Nov 14, 2009 | 08:22 PM
ghostrider69's Avatar
ghostrider69
I just ordered new bearings, again, and spacer stock. Hopefully they will be here by next weekend. Tomorrow I am going to work on getting it right with the bearings I have. That way when the new stuff shows up I will know exactly what I need to do. I was hoping to have it all done this weekend but nothing ever pans out like you want it to. Well, I guess I can mess with that hub tomorrow and then get the headlight wiring straightened out so I can bolt the tank back up. My wife loves to hear about problems like this because she says now I have time to do the things around the house that I put off to work on the bike. Man that link to those wheels are tempting. If they only had chrome rims.
Old Nov 15, 2009 | 01:30 AM
SURFOR Chop's Avatar
SURFOR Chop
Don't remember the deal with the headlight wiring, but only know mine was a 2-wire headlight vice 3-wires originally, as well ... I just did a trial and error method ....
Looks like you're making good progress ... I know how frustrating it can be when you're in the middle of your project and something doesn't go according to plan ....
Once you're all done and getting some time in the saddle, you'll look back and think about how it was all worth it ....
Good luck, bro ...
R/
'Chop
Old Nov 15, 2009 | 09:59 AM
ghostrider69
Thanks chop, I got the wheel back apart and got the headlight wired up. If anyone wants to know I used the stock wires coming out of the stock headlight with the stock plugs. The stock plug plugged right into the aftermarket headlight and everything works as it should. Now to just sit back and wait on the wheel parts. If everything would have worked out like it should have then I could be riding today instead of mowing. Oh well.
Old Nov 15, 2009 | 10:59 AM
bikerlaw's Avatar
bikerlaw
Thanks for a great post. I'm in the middle of my own wide glide conversion as we speak. I, being the consumate cheap a$$ went with the "nowhere near as nice" kit from Jireh, but this has been a very helpful and useful post. You bikes gonna look nice.
Old Nov 15, 2009 | 02:57 PM
ghostrider69
Bikerlaw, I originally wanted to go all aftermarket with the frontend. One of those phat fork fronts complete with wheel and axle. But me being the budget minded and my wife popping the whip everytime I spend money, I thought it would be cheaper to convert this way but I am over $600.00 into it and still not finished. I found out what was causing the binding. When I bored the hub, I did not bored it out enough which caused the inner bearing spacer to rub on the inside of the hub right where it has MADE IN AUSTRALIA cast into the inside of the hub. That problem is taken care of and a quick mock up showed great results. So now I have to just sit back and wait on my new bearings and outer spacer stock. It just goes to show ya. If I would have taken my time and did it right the first time I could be on the road today. The sad part about it is the bearings that I just pulled which cannot be reused came from the stealership for $46.00 and the stock spacers that are to short $10.00. I figure it was a learning experience.
Old Nov 15, 2009 | 04:40 PM
m i k e's Avatar
m i k e
lookin good you will dig the wide glide front as you probably already are
turning and parkin will take a little more time but who cares?
Old Nov 16, 2009 | 09:40 PM
lewistg's Avatar
lewistg
i did a similar upgrade on my 05 fxd a couple of years ago. aftermarket 5 degree triple trees, stock length fxst fork tubes, dealer take off lowers and had to buy a bearing kit from the dealer to convert my 1" front bearing to 3/4 since i wanted to keep my stock laced wheel. i think I bought a 3 wire headlight but dont remember. i did have to shim out my caliper. and i am still running with a speedo because of the lack of alternatives. the center axle spacer was in the bearing kit but had to cut the side spacers with stock provided in the kit. it is a pain getting all the right dimensions.
Old Nov 17, 2009 | 10:14 PM
ghostrider69
Update: The bearings and spacer stock will be here Thursday. So the good Lord willing and the creeks don't rise I'll have this bitch on the road this weekend.
Old Nov 17, 2009 | 11:17 PM
Vinsil's Avatar
Vinsil
Nice! Sucks about the problems, but man...everything I do major project wise turns into a mess.
I take it as a learning experience like you. Looking forward to your results as I have the same bike and plan to do a similar conversion.
Old Nov 18, 2009 | 06:25 AM
Frog33's Avatar
Frog33
Great post, I am gathering things needed to do this very thing. Will the Chrome lowers off a 06-Later FXDWG fit on the stock tubes of a 08 SG? I plan on using the trees off a WG and keeping everything else stock, minus 21" wheel and axle. but if using the lowers off a WG will make lining everything up easier seems that would be the way to go. Thanks
