07 FXDC mini tach install help
Old Nov 17, 2009 | 06:38 PM
09B29's Avatar
09B29
Default 07 FXDC mini tach install help
I have finally a silver face gauge mounted on my FXDC
I have some 18 gauge wire
i know where the Hot and Grnd wires go
spare fuse for hot
grnd to frame grnd
My question is
Where do I get the tach signal from (pink)???
My dealer says the pink wire ( tach signal wire, currently not being used) should be in the speedometer harness under the gas tank
can anyone shed some insight into this?
PS I do have the factory service manual
Thanks
Old Nov 17, 2009 | 08:33 PM
murphdog's Avatar
murphdog
The pink wire went away after '03. You have to pick up the signal from pin 3 on the ECM connector under the electrical cover on the left side. If you got the mini tach new, it should have come with a wiring harness that includes the terminal you need to plug into the ECM connector. Otherwise, you'll need to get a 72076-00 terminal. Unless they've changed the instructions in the last couple years, they suck.
Here's a how to on the install (not mine). http://www.shareaproject.com/pages/i...i,2354,00.html
Old Nov 17, 2009 | 08:41 PM
09B29's Avatar
09B29
thanks
ive got gauge only
got some 3 conductor 18 gauge for 7 bucks
verses 100 + for a wiring harness from Harley
I try to buy all stuff from Harley but
sometimes it is Ludicrus
Its just 3 wires
Old Nov 17, 2009 | 10:28 PM
jarhead45's Avatar
jarhead45
I did mine this way ... you dont have a pink wire....
https://www.hdforums.com/forum/dyna-...erant-way.html
firstrock
Oct 16, 2012 09:22 PM
Commander Data
Oct 31, 2011 01:50 PM
jbied
Oct 25, 2010 12:30 AM
jbied
Mar 18, 2009 04:25 PM
jskwarek
Sep 18, 2007 07:08 AM
