Did something bad ... bolt broke off
Good LUck.
Good LUck.
the key is to drill a small hole in the center of the broken stud, and typically about 1/4 into the broken stud. Notice I said a number 40 drill bit, that's usually where I start or might work up to a number 30 drill bit if I'm dealing with a typical bolt say 1/4, 5/16 which are usually what were dealing with on our bikes.
Also you need to make sure and drill straight into the bolt, not cockeyed or at an angle, this is why I said a 40 drill bit. If you use a bigger bit and go at an angle then you take the chance of damageing the threads when extracting broken screw out, in that case you open up a can of worms because you would either have to retap the hole or put in a helicoil.
Another reason I mention get some good ezouts is cheaper ones break when you try and turn em out, I've done it in a pinch, and I won't do it again, because they are a **** to dill back out.
By the way as I am writing this I found a quick article that has some pics and additional info, check it out and I think you'll find with a little patience you can fix it up and get it back together.
I notice they mention heat, I also have used that in very stubborn cases, you gotta torch, don't need a welder just a good butane to throw heat on there, but your not dealing with tighter than hell, rusted out, areas, at least your primary shouldn't be anyway.
http://www.asashop.org/autoinc/may2003/techtotech.htm
Best of luck with your project.
