Amsoil
Old Jan 16, 2010 | 01:12 PM
texas_speed_freak's Avatar
texas_speed_freak
Originally Posted by Faast Ed
But their own website also makes it clear, that they do NOT recommend those extended intervals to any motor that has been modified from stock.
True. I dont go the double intervals anyway. Even on my stock honda civic. But i feel the oil is superior to most other oils and i trust it to go further than the regular change intervals, even on modified engines. I have also tested the cooler running of it and found out firsthand that its true(20+ degrees cooler on a big twin). Plus synthetic in general has a higher breakdown point than conventional oil so thats a plus.
Old Jan 16, 2010 | 03:41 PM
gplarryv's Avatar
gplarryv
Originally Posted by Lorance66
Amsoil is good oil. I use 20W-50 in the primary and engine and 75W-140 severe gear in the transmission. The gear oil actually dampened the 5th gear whine a little bit. I still faintly notice it but nowhere near what it was.
I run Amsoil in the Eng and Primary
I was running Amsoil in the Trans but Switched to the Red Line Tranny oil. It cut down the 5th gear noise even more, it is thin and it sticks to the gears does not run off
Old Jan 16, 2010 | 04:07 PM
springerGT's Avatar
springerGT
I have a temp guage on mine
and it definately runs cooler b y 10 degrees with the Amzoil.
Old Jan 16, 2010 | 04:26 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Wow, this is a new and interesting topic...maybe it belongs in the oil and oil related topics section, with the 3 million other posts saying the same thing.
Old Jan 16, 2010 | 04:34 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Cmon Dan...you know there is only 2.7 million..
Old Jan 16, 2010 | 05:08 PM
MidnitEvil's Avatar
MidnitEvil
I run the 20W50 in all 3 holes. Works great. I'm lousy at changing my fluids at regular intervals. Usually go 20-40,000 miles between changes in my cars. Bike I try to do at least every 10,000. I get 200,000 miles out of my Jeeps no problem. No idea on the bike yet.
Old Jan 16, 2010 | 05:46 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Yeah, I know, but I was just exaggerating to sound like I knew what I was talking about. Serious subject that it is...
Old Jan 16, 2010 | 05:50 PM
Faast Ed's Avatar
Faast Ed
Oh my,...... and you admit to that?
You should be tied to a post and whipped repeatedly!
Old Jan 16, 2010 | 06:31 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Ever wonder how often the engine oil is changed on the airliner you fly on?
Unless something shows up in the oil sample, it is never changed.
Old Jan 16, 2010 | 07:29 PM
Faast Ed's Avatar
Faast Ed
Do you have a link to back that up?
