Taillight bracket
Old Jan 29, 2010 | 11:55 AM
pinoy's Avatar
pinoy
Default Taillight bracket
Anyone knows how to remove the taillight bracket on a WG-07?
Attached Thumbnails Taillight bracket-038-kopia.jpg   Taillight bracket-p1010458-kopia.jpg
Old Jan 29, 2010 | 12:30 PM
johnd5412's Avatar
johnd5412
If you are trying to access the taillight bulb, then you just unscrew those two phillips head screws holding the bracket onto the tail. Once you have done that just pull it off and it will hang by the wires of the brake bulb. Perhaps I'm not understanding what you are asking? I just replaced my bulbs on my 07 WG 3 days ago to LED so it was that easy.
Old Jan 29, 2010 | 01:04 PM
pinoy's Avatar
pinoy
Thanks for your answer but i mean the whole plastic thing
Old Jan 29, 2010 | 02:30 PM
elevenbravo78's Avatar
elevenbravo78
Smile
the bolts run through the fender, fender struts, and fender strut chrome covers that hold the taillight onto the rear of the bike. the turn signals run through it as well. you will have to cut the turn signals to remove the plastic tail lamp assembly. Its aggravating that they couldn't of thought of a way to just simply plug the turn signals in, enstead of having to cut them. There is also electrical wiring running underneath the top portion of the rear fender also. it unplugs from the tail lamp assembly at least. Hey were did you get that round sissy bar? I've been looking for one. Cyclevisions has a 18 incher but thats just too tall for me.
Old Jan 29, 2010 | 02:43 PM
pinoy's Avatar
pinoy
Thanks a lot elevenbravo78!!,i bought that sissybar here in Sweden,
Just look for:
http://www.khromewerks.com/index.htm
Old Jan 29, 2010 | 05:11 PM
SC-Longhair's Avatar
SC-Longhair
It looks like you will have to drop the shocks off the top mount...remove the strut covers to access the one bolt on each side. The rest should be easy.
groundpounder51
Nov 13, 2013 10:37 PM
emerican19
Nov 15, 2011 04:41 PM
fob_speicher
Jun 16, 2008 01:43 PM
atrox88
Jul 25, 2006 10:10 PM
Timmer
Apr 18, 2006 06:50 PM
