Help Primary Bolt Stripped
Also, what's this? "18. motorcycle lift, the yellow one. Can't live without it" I need one of those too.
Thanks in advance,
malcolm
If I might ask, what range of Snap on Torx bits do I need for all the fasterns on a 06 HD? I'll order a set.
Thanks in advance, malcolm
I have a set ranging from 15 to 55, don't forget the 27.
I like the gold anodized ones, I believe SnapOn lists them in the catalog as Heavy-Duty Removal.
Ebay Item number: 130011227352 9 pieces 20.49 is current bid
motorcycle lift, the yellow one, Click on my gallery pix to the left, there are a couple action shots.
edited to add:
I am replacing a lot of the pretty torx heads with the grade 9 allens, or hex heads.
I'm not all that much into pretty. I was gonna turn off the lights anyway.
mud
