Strange Dyna Behavior...
Old Mar 7, 2010 | 03:32 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
My guess is water in the electrical system.
Pull the fuse box cover on the left side of the bike (it pulls right straight off) dry it out with a hair blow dryer. Remove each relay & fuse one at a time and dry with dryer and then grease with dielectric grease and reinstall (permatex makes it and get it at the auto parts store). Dry start/run switches with hair dryer and sray with silicone spray. Dry ignition key lock & silicone spray. Dry plug wires & coils & silicone spray. Pull off seat and dry wire harness plugs and unplug one at a time & lube with dielsctric grease. Pull battery box cover, tighten battery cables and grease. Check battery ground strap on frame for tightness & grease.
Old Mar 7, 2010 | 04:36 PM
50magnum's Avatar
50magnum
In Brazil do you guys use an additive to your fuel? Ethanol from corn or other? I don't really think that would be it unless you fueled somewhere where only the locals have their fuel and that can be dicey, as I recall driving around for a month in remote sections of the Philippines in 2002.
I know both my manuals for my bikes specify to not use anything with methanol, as it says doing so can result in fuel system management components failure, engine damage and/or equipment malfunction. I doubt that's it since you have live there and most likely already knew that anyway.
Old Mar 7, 2010 | 05:27 PM
Ratbob's Avatar
Ratbob
Have you checked your diagnostic codes? There is a link to the 'how-to' on Mud's *Search Topics* page pinned to the top of the Dyna Glide Models Forum page. Here's the link.
Old Mar 7, 2010 | 06:27 PM
BeavisRules's Avatar
BeavisRules
I ran with an open air filter for awhile but I had a tendency to get caught in some major downpours here in Colorado. The filter would get saturated and the bike would do exactly what you described. Once the filter would dry out the bike would run strong again.
My vote is on the filter getting wet. Be aware though, the filter would have to be VERY wet for it to start running like crap so it could be electrical if the rain wasn't too bad.
Old Mar 7, 2010 | 06:50 PM
BullyDog's Avatar
BullyDog
Another reply that is in favor of bad fuel! Try what these guys said and you should be ok. Good luck. C
Old Mar 7, 2010 | 08:10 PM
sata6's Avatar
sata6
Check your plug on the throttle position sensor i had the exact same symptoms you describe after being caught in the rain its the one on the bottom of the ei unit i believe. i went through all of my plugs and put dielectric grease in them of course it was the last plug i checked and after that it was right as rain so to speak.
Old Mar 7, 2010 | 08:12 PM
PigInaBlanket's Avatar
PigInaBlanket
I had this same thing happen last May when traveling through a few hours of rain during a Saddlesore 1000 ride. Once the rain cleared up the bike ran fine. Never happened again.
Old Mar 8, 2010 | 05:02 AM
dsavi's Avatar
dsavi
Here we have around 20% of ethanol (from sugar cane) added on all the gasolines available. I only use the premium ones, anyway.
BlackBobber08
Jun 1, 2018 05:51 AM
canadayman
Jul 21, 2015 11:02 PM
Rustybeater91
Apr 19, 2014 08:43 AM
mtaylor1111
Apr 29, 2011 08:39 PM
Camo King
Aug 6, 2010 07:56 AM
