Need some wiring advice
Old Mar 13, 2010 | 07:54 PM
zonutt's Avatar
zonutt
Default Need some wiring advice
Alright guys, time to hold my hand again. I've spent the afternoon looking in old searches, and couldnt find an exact answer to my satisfaction so here goes. I bought a lighted side mount plate and need to know how to wire it.
It has a white and a black wire. I found the rear lighting harness under the seat which has a purple, a black, a blue, a yellow/red, a brown, and a orange/white wires. Gonna use posi-lock connectors. Am I right in thinking that I connect the black wire from the license plate to the black wire from the tail light and the white wire to the blue from the tail light? Fellas, I know this is long and drawn out, but I need some step by step directions, im an idiot when it comes to stuff like this. Thanks for your time.
Old Mar 13, 2010 | 08:40 PM
Taddeoeg's Avatar
Taddeoeg
Can't offer color specific directions since I don't know what year/model your bike is and it's likely not the same as mine anyway.
But why isn't this as simple as moving the wires from the stock rear plate mount to the new side mount plate? I'm assuming you're trying to power the plate light, right? Just attach the two wires from the new side mount set up to the two wires that light the stock plate.
Old Mar 13, 2010 | 08:57 PM
8541hog's Avatar
8541hog
Take a look at the wiring diagram at the bottom of this page link, has the color codes.
PM if you have questions still.
http://www.8541hog.com/taillight.html
Old Mar 13, 2010 | 08:58 PM
ackman1968's Avatar
ackman1968
Skip the posi locks! Use those and you are asking for trouble. They comprimise the wire, allow moisture in and over time with vibration the wire can break. Throw out the year of your bike and some one should have the right diagram for the wire colors.
Old Mar 13, 2010 | 09:47 PM
zonutt's Avatar
zonutt
Its a 07 dyna superglide. Thanks
Old Mar 13, 2010 | 09:54 PM
jdaws's Avatar
jdaws
He is right, no posi locks!
However you splice them in, the wiring needs to be sealed from the elements or it will never last.
Old Mar 15, 2010 | 05:21 PM
zonutt's Avatar
zonutt
Thanks for the help all, I appreciate it.
Old Mar 15, 2010 | 05:35 PM
Hickey's Avatar
Hickey
I'm pretty sure your going to connect it to blue and black. black being the ground obviously, and blue being the running lights
Old Mar 15, 2010 | 05:38 PM
spotzhill's Avatar
spotzhill
+1, if it is for the plate light don't get to crazy. you should be able to use the old light wires
Hazzmatt
Jul 8, 2016 05:08 PM
Just Enough
Jul 14, 2015 07:37 PM
SulphurDave
Oct 14, 2011 07:40 PM
PearlWhiteGT
May 19, 2011 11:52 PM
blinck27
Apr 19, 2006 01:33 AM
