49mm WideGlide Width
Old Apr 13, 2021 | 03:34 PM
  #41
2cyl john's Avatar
2cyl john
Stage I
Originally Posted by bzzrd2
As I said above. If you are widening by 35.357 mm, add half of that (17.678 mm) to each wheel spacer to center the existing wheel. You will now have to MOVE THE CALIPER IN by the same amount to center it over the rotor (the rotor is still bolted to the hub in the same location so it is now an additional 17.678 mm away from the slider mount) so you just add 17.678 mm spacers to move the caliper in....same amount of spacer if you are using your existing fender. I'm not using different calipers, or wheel so it will all line up.
I once built my own wide glide tripple tree and instead of moving the caliper i had spacers turned to move the brake disc outward. Bought disk bolts and bolted the spacer to the hub and then bolted the disk to the spacer. Is safer than moving the calipers inward toward the hub.
You can see the spacers
Guitardude
Dec 12, 2012 09:06 AM
jmat1980
Apr 18, 2012 09:16 AM
sniper77
Motorcycles For Sale
Apr 26, 2009 04:43 PM
vetto
Sep 16, 2008 11:32 AM
gilmour68
Feb 27, 2008 01:25 AM
