07 street bob
Old Apr 5, 2010 | 09:31 PM
pickiam's Avatar
pickiam
Stage III
Default 07 street bob
i have an 07 street bob with forward controls. the plug in the outer primary where the shifter used to be is leaking. the dealer gave me a sample tube of blue loctite. i popped it off, cleaned it up and re-applied the loctite. it is still leaking, i was wondering if anyone knows what to do
Old Apr 5, 2010 | 09:40 PM
ghostrider69's Avatar
ghostrider69
There is a small round gasket that goes between the inner and outer primary covers between the shifter tubes that has shifted or completely fallen out that is causing your leak. You could remove the plug and use RTV silicon on it and reinstall it and it should fix it. Or you could remove the outer primary cover and install a new gasket with RTV silicon on both sides of it and reinstall the outer primary cover.
Old Apr 5, 2010 | 10:03 PM
SuperFastGlide's Avatar
SuperFastGlide
your dealer is an idiot lol
Old Apr 6, 2010 | 12:07 PM
pickiam's Avatar
pickiam
Stage III
thanks for the info
Old Apr 6, 2010 | 12:09 PM
Wonkaboy's Avatar
Wonkaboy
Definably + 1 on that !
Old Apr 10, 2010 | 08:29 PM
pickiam's Avatar
pickiam
Stage III
yeah went back to dealer to get the gaskets, the guys in the back know a little more than the guys in the front. thanks again.
Old Apr 10, 2010 | 10:07 PM
mikeault's Avatar
mikeault
Keep that loctite though in case your turn signal fluid is running too hot. lol
Parts dept. is amazing sometimes.
Bob30247
Jun 6, 2025 10:30 AM
jojo2dog
May 26, 2012 07:26 PM
skidsareforkids
Aug 30, 2010 05:33 PM
shadowbob
Jul 3, 2010 12:05 AM
cadore
Jan 25, 2009 07:29 PM
