Primary Cover ????
Old Jan 25, 2009 | 02:04 PM
cadore's Avatar
cadore
Default Primary Cover ????
A friend of mine sprayed sometype of cleaner on his 07 Soft-tail Standards engine, and it made spots on the primary cover. I recently replaced my primary cover 07 FXD, and I want to let him have it.
Is there a difference in primary covers, other than the shift hole?
Old Jan 25, 2009 | 03:22 PM
jmpancoast's Avatar
jmpancoast
On your 07 covers, the "tunnel" which housed the shifter shaft is formed when the inner and outer meet. Because his did not have the shifter shaft, the casting of his inner is different and will not meet your outer to form this tunnel. Therefore, primary fluid will leak from your outer.
He will need to seal this hole somehow in your outer. He can use a chrome carriage bolt and an appropriate rubber sleeve around it to seal this hole from the outside in. I believe others have also used a correct size freeze plug to seal the outer from the inside, and the HD chrome plug for dressing up the outside.
Old Jan 25, 2009 | 05:59 PM
cadore's Avatar
cadore
Thanks Man....We will give that a shot.
Old Jan 25, 2009 | 07:13 PM
JRK5892's Avatar
JRK5892
have him just use some S100 or pig spit on the primary that should remove any of the spots
Old Jan 25, 2009 | 07:29 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If its polished aluminum get a can of mother's polish or never dull and start appling some elbow grease.
jojo2dog
May 26, 2012 07:26 PM
coop creek
Mar 30, 2012 09:01 PM
SURFOR Chop
Apr 26, 2009 10:14 PM
jrsmith_80
Aug 21, 2008 08:33 PM
helotaxi
May 28, 2005 03:27 PM
