Vibration while pulling in 5th/6th
Old Jul 15, 2012 | 08:41 PM
  #41
lo-rider's Avatar
lo-rider
Originally Posted by greenvarmit
So I don't feel the vibration in any other gears, only 5th and 6th gears and it's while pulling, example, cruising at 55mph in 5th and roll on the throttle or 6th at about 65 mph and roll on the throttle i get a strong vibration in the pegs up to the seat and in the bars...it's only in 5th and 6th gear. It almost feels like there's a loss of power too...
...I get the vibs...between 1700-1800...
Originally Posted by JimmysFXDC
...you're bogging the engine....
Originally Posted by seniorsuperglideE8
...you lugging the engine...
Originally Posted by joe.1955
...low rpm / high torque situations, like cruising on the freeway. It actually felt like I was lugging the engine...
I was convinced it was a weak compensator spring pack allowing the torque pulses through that it was supposed to absorb...
OP--It's the firing impulses that you're feeling. Quit lugging your engine and you'll discover that the "problem" has disappeared.
Old Jul 26, 2012 | 03:08 PM
  #42
rong84's Avatar
rong84
Stage III
i have a 2007 dyna with 11000mi. on it and the vibration is all over the place I replaced front motor mount didnt help. Just took it for another ride noticed vibration is much worse at higher rpms its a very fine vibration makes my hands numb any ides thanks.
Old Jul 26, 2012 | 03:25 PM
  #43
Gommee's Avatar
Gommee
Devil's Advocate
Did you add a spacer?
https://www.hdforums.com/forum/dyna-...with-pics.html
Old Jul 26, 2012 | 05:06 PM
  #44
missedem's Avatar
missedem
the shift recommendations for the dyna in the book are for break in period. I hope it turns out the compensator is the problem . chasing down problems can be a bitch. BTW you want to ride your engine hard once in awhile or you will get more carbon build up and it will run like crap. Riding the bike too easy all the time is not good for the motor. Good luck I hope it turns out to be a simple fix for you.
Old Jul 26, 2012 | 05:20 PM
  #45
jpooch00's Avatar
jpooch00
I've read that when the pressed-together crankshaft in the twin cam engines "scissors" (slips on the crank pin) it can cause the vibrations that people are describing in this thread. The way to check it is to check the runout on the camshaft side of the crank.
The MOCO has done nothing to address this problem and they hate to warranty it because of the cost. They increase the runout spec every year in an attempt to avoid warranty claims. It's up to 012" this year - which is absolutely ridiculous for an acceptable amount of crankshaft runout in any engine - plus, they just install another crankshaft that is very likely to develop the same problem again later, after the warranty has expired.
There are welded aftermarket cranks that will permanently fix it but, naturally, the MOCO won't let their dealers install one under warranty.
NYdyna
May 2, 2012 11:40 AM
bullwinkle
Apr 19, 2008 07:55 AM
roadhawg
EVO
Jun 27, 2007 07:29 AM
gilmour68
Oct 24, 2006 08:30 PM
