Forward Control Question
Old Apr 12, 2010 | 11:29 PM
X90's Avatar
X90
Default Forward Control Question
o.k. I am getting geared up to install forward controls and will tear into my primary. My question is what covers the hole in the inner primary on the backside? Reviewed many posts and instructions and nothing seems to answer question what plugs the whole on the innner primary after removing the mid shifter shaft.
Old Apr 13, 2010 | 01:39 AM
seadblyou's Avatar
seadblyou
6th Gear
There is a gasket in the kit for the mid position shaft that rests between the primary chaincase housing and the primary cover. Because of this, there is no need for a gasket for the housing.
Old Apr 13, 2010 | 07:49 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Hole remains open on the back side and is gasket-ed on the inside between covers. Your kit should come with a little chrome cap to plug the hole in the otter cover (this cap is cosmetic only).
Old Apr 13, 2010 | 08:22 AM
mrkt50's Avatar
mrkt50
Like others have said, there's a donut shaped gasket between the two halves. (part no. 63869-06) My kit did not come with one, (49080-06a) so I reused the original. That was a mistake, started leaking after a few months, so I had to replace it.
So, if kit didn't come with one, do yourself a favor and get one before you start. Cost about a dollar.
Old Apr 13, 2010 | 08:27 AM
jaqmes's Avatar
jaqmes
keep reading you don't have to take the primary apart. most are cutting the shaft off and pulling it out.
Old Apr 13, 2010 | 10:31 AM
Punchsmack's Avatar
Punchsmack
+1
Even if you don't do the "cut and pull", leaving it in won't be a big deal. And it saves a TON of time too. I could have had my forwards on in 35 mins....but I milked it a bit to spend more time with my dad.
Old Apr 13, 2010 | 07:43 PM
X90's Avatar
X90
Thanks for the replies. I'll check for the gasket.
As far as tearing into the primary, I have an 06 and want to check the screws on the stator and tack weld those suckers.
I'm also going to change the IPB with a baker bearing.
One other question, what adhesive did folks use for the decorative cap?
Old Apr 13, 2010 | 09:07 PM
mrkt50's Avatar
mrkt50
I used blue locktite, it sorta snaps in.
Bob30247
Jun 6, 2025 10:30 AM
Hephaestus
Sep 28, 2016 09:12 PM
matts Dyna
Jul 23, 2011 12:48 PM
Trout
May 3, 2007 03:51 PM
