FXDF 2009 Starting Problems !!! Please Help !!!
Old Apr 21, 2010 | 01:14 PM
booshdoctor's Avatar
booshdoctor
Default FXDF 2009 Starting Problems !!! Please Help !!!
Hello My Brothers !!! I need your help again !!
I went to start my monster... which I havent for a month and a bit !! So Ignition on, run..... the sound of the fuel pump was a bit weird.... then Start... a big Starting sound and then Cling, Cling, Cling... and the lights and instruments were flickering... ??? Did it again ..ignition on, run fuel pump sound.. not as loud as usual ??? then start... Cling, Cling, Cling... and flickering lights... checked the spur-plugs.. they were fine !!! I think the sound comes from the left side of the engine .. its like hiting 2 pans together ??.. Cling, Cling, Cling..?? my last thought was maybe the Battery was a bit discharged .. so I have put it to charge.. I will see in the Morning !!!!
Any Ideas from you my Brothers ??? I'm so I do not know what to do..
Please help me out !!!
Old Apr 21, 2010 | 01:25 PM
shimmon's Avatar
shimmon
It sounds like maybe your battery is low, did you check the volts? With lights flickering is also another indication of a low battery or even a loose connection (ground or positive cables, OR EVEN GROUND TO FRAME). After a good charging cycle (charge and cooling time) then you may want to check volts again before you go and put it back in the bike. Then you can check battery voltage while cranking over engine (might need a buddy to help).
I'm thinking maybe a loose connection or low battery.
Old Apr 21, 2010 | 01:39 PM
booshdoctor
I Hope so Shimmon.... I will check tomorrow !!! Thanks for letting me know !!! I never had a problem before ..she always starts with no problem !!! and the cliking sound ?? Battery ??? the lights are bright and horn working and indicators a swell.. No problem !!! Do you think if I push her.. is she going to start ?? I wont be able to sleep tonight...
Old Apr 21, 2010 | 01:53 PM
Phrogman's Avatar
Phrogman
The clinging sound could be the sound of the starter relay closing but there's not enough voltage for the starter jackshaft to engage and turn over the motor. I'd try it after a charging and you should be fine.
Old Apr 21, 2010 | 01:56 PM
booshdoctor
Thanks a lot Fhroman...... I will try 1st thing in the morning....
Old Apr 22, 2010 | 09:50 AM
booshdoctor
Thanks a lot for your Help !!!! It was the Battery !!! Now its working Great !! thanks my Brothers !!! Yammas
Old Apr 22, 2010 | 11:45 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Get one of these and wire in the pigtail. It is the same one as the HD one.
http://www.amazon.com/gp/product/B00...76406MRT9JB3FC
Keeps your battery hot all the time.
Old Apr 22, 2010 | 06:25 PM
FATBOB.'s Avatar
FATBOB.
get a battery tender, the alarm system always takes abit of juice.
your battery will last alot longer too ...my 2 cent....
Wezdog
Feb 20, 2013 05:06 PM
Roger Williams
Feb 7, 2013 04:17 PM
Young buck
Engine Mechanical Topics
Nov 5, 2012 04:52 PM
ADS0105
Jul 18, 2010 01:59 AM
Somber Goat
Sep 30, 2008 04:47 PM
