Hard Starting
Old Apr 27, 2010 | 07:11 PM
Wonkaboy's Avatar
Wonkaboy
Just like a fuel injected car they can turn a couple times too and my bike does it as well but not all the time , i think it's normal operation .
Old Apr 27, 2010 | 08:51 PM
sniper77's Avatar
sniper77
Okay.
The reason you should bypass the system check when you turn on the key with a cycle that has a piggyback tuner is because it doesn't give the ECM a chance to notice there is a piggyback system connected to it.
The stock ECM will shoot a blast of fuel to the cylinders and choke the air as if it was stock. This allows the engine to fire before the piggyback tuner can start telling lies to the ECM and get the damn thing confused before it has a chance to start the engine.
If you run an aftermarket ECM or a stock ECM with a SERT or SEST you don't have to fret with "tricking" the ECM into starting the engine and can wait for the systems check it goes through while the fuel pump is charging the line.
If you run a piggyback like the Powercommander you should hit the starter as soon as you turn on the ignition.
Old Apr 27, 2010 | 09:05 PM
thedonthere's Avatar
thedonthere
Originally Posted by lockednloaded
Gee, thanks for that answer. Very informative.
You're quite welcome. Why don't you just give it a try?
Old Apr 27, 2010 | 11:22 PM
nrs2420's Avatar
nrs2420
I never heard that about not waiting for the prime, I do have the power commander V. I will try that tomorrow morning and see how it works. Also the bike will be going in for it's 1000 mile service on Friday, I'll have them look at it.
Old Apr 28, 2010 | 10:22 AM
nrs2420's Avatar
nrs2420
well tried the not waiting for the light thing and it worked perfectly.
Old Apr 28, 2010 | 10:46 AM
FATKEVIN's Avatar
FATKEVIN
I had the same problem as you. I checked the cables and they seemed fine but I gave them a quarter turn more and that solved the problem. Check the ground cable on the frame too. Mine also started fine when it was warm, the longer start was only when it was cold.
carburetorjones
Jul 15, 2019 09:20 AM
EdsRoadGlide2017
Nov 23, 2016 05:05 PM
Hardman679
May 15, 2016 03:10 PM
cgsiluk
Feb 9, 2016 07:27 AM
David O'Neal
Feb 7, 2016 10:59 PM
