Vibes for me....
Old May 5, 2010 | 12:40 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Default Vibes for me....
The vibrations in my foot pegs is getting bad. Also, just recently I've noticed a clunk in my right foot peg. Mostly happens while going over bumps, but can also sometimes be felt while engine braking. I first noticed this clunk right after changing the front and rear brake pads. I did the pad swap by the book so I'm thinking it's coincidence. Looks like I'll be changing out the front motor mount...any thoughts?
Old May 5, 2010 | 01:01 PM
shimmon's Avatar
shimmon
Did you do the shim thing? I havent and am getting vibes up threw the apes... Had it before but its a bit worse since these bars are taller. But i've heard people getting rid of handlbar vibes from the front shimming process. Didnt know if you had done this or thought bout it? I'm gonna do it in the coming weeks.
Old May 5, 2010 | 02:13 PM
Grendel4's Avatar
Grendel4
Pretty sure there was tech (service?) bulletin regarding some '06 models and motor mounts. By your sig-line, is yours an 06? Might be worth a look even if it isn't.
Old May 5, 2010 | 03:58 PM
HOGRIDA_06's Avatar
HOGRIDA_06
I did try the shim technique...when I loosened the two bolts and I had about 3/32" of a gap at the top bolt and no gap at the bottom. The rubber on the isolator is definitely touching the bracket and from what I've read thats not right.
Old May 5, 2010 | 06:27 PM
MLWilson's Avatar
MLWilson
HOGRIDA, I had similar symptoms like yours, changed out the front mount and it all went away.
Old May 5, 2010 | 07:48 PM
HOGRIDA_06's Avatar
HOGRIDA_06
Thats what I'm hoping, gonna place an order with zanotti's tomorrow.
Old May 17, 2010 | 07:38 AM
HOGRIDA_06's Avatar
HOGRIDA_06
Finally mounted my new isolator and it made a world of difference. The clunk I was feeling in my pegs is gone and I'm back to the normal amount of vibes. Here's some pics to some the 2 isolators, you can see the mounting point on the old isolator is higher than the new causing it to rub on the frame.
Old May 17, 2010 | 08:17 AM
SC-Longhair's Avatar
SC-Longhair
Interesting. The old rubber is at an angle. The new rubber is perpendicular (triple letter word score??)
Thanks for the pics, Hog. Appreciate it.
Old May 17, 2010 | 08:24 AM
8541hog's Avatar
8541hog
Hogrida
I would be curious to see the 2 compared again in a couple months. It looks like they may have started out the same but the old conformed to where it needed to be.
I am curious if the new one will look like that after a couple thousand miles.
Save your old mount.
Old May 17, 2010 | 09:15 AM
rounder's Avatar
rounder
when I installed a new mount, it quickly ended up in the same position as the old one.
