Warning! Check your tires!
Old May 21, 2010 | 02:52 PM
Zig Zag 2010's Avatar
Zig Zag 2010
Default Warning! Check your tires!
Old May 22, 2010 | 03:04 PM
op01jre's Avatar
op01jre
Ya same think but at 1k miles. Took my bike to the dealer for its 1k service. They called after about 2 hours and told me my front tire didnt look right and wasnt wearing normal. They covered it under warrenty and replaced it for freee.
Old May 22, 2010 | 06:57 PM
manofsteele2003's Avatar
manofsteele2003
Don't have any cracks but I did find a nail in my rear tire. Cost me $135 to have a new tube put in it, blows.
Old May 22, 2010 | 07:43 PM
05DYNALOW's Avatar
05DYNALOW
Check the date code on your tires. It's found at the end of the DOT #'s. Shoud be a four digit #. Tells you when they were made. Example: 1404 would be the 14th week of 2004. Tires are only good for 6 - 7 years regardless of whether or not they are in use. ABC news did a special report on tires and dealers that were/are selling new tires that are older than 6 years. This shouldn't be the case on a 2010 bike but it doesn't hurt to get the info out there. Here's the link to the special report:
http://abcnews.go.com/Video/playerIndex?id=4826897
TK
Old May 22, 2010 | 08:06 PM
mikeault's Avatar
mikeault
That's a defective tire man. Get it replaced. The stock dunlops HD uses wear fast, but not that fast.
Old May 22, 2010 | 08:40 PM
2deuce's Avatar
2deuce
had a big bubble in the sidewall on my Deuce at 2100 miles. covered under warranty.
However, checking them before every ride is a good idea. Tires is the only thing between us and the ground!! Same with brake lights and turn signals
Old May 22, 2010 | 09:16 PM
Zig Zag 2010
Old May 22, 2010 | 09:37 PM
jason628's Avatar
jason628
Greetings,
I'm just curious if the replacement will be a Dunlop or a Michelin. I've noticed a lot of the later ones have Michelins on them.
Old May 22, 2010 | 10:41 PM
icecaps's Avatar
icecaps
Reading More Posting Less
Saw this somewhere:
Remember to check your tires,
Or you'll leave this world like you came into it,
On busted rubber.
Old May 23, 2010 | 12:17 AM
INADAZE's Avatar
INADAZE
Just ran into the same exact problem on my WG. The dealer warranted the tire during the first service. It started showing up after only a few hundred miles.
I'd definitely recommend checking the tread if you own a new bike!
