Hesitating - which saddlebag size ?
http://www.saddlemen.com/store/index...oducts_id=5161
This is what it looks like with Easy bracket mounted on the bike :
So "flawless" fit.
Original post follows :
I'm hesitating on the size of saddlebags to order for my '10 Street Bob. The rear turn signals are relocated and I'm getting easy brackets for mounting them.
Basically, it's between these two :
Dimensions: 16″ W x 11″ H x 6-1/2″ D
http://www.jpcycles.com/product/830-...91&results=100
Dimensions: 14″ W x 12″ H x 5-1/2″ D
I'd much prefer the first one, because obviously they hold more stuff. However, I'm afraid that even with the rear turn signals relocated, they might be too big of a fit between the shocks and turn signals.
The second ones are a nice compromise, but they are higher than the first, which poses another fitment problem, rubbing on the belt guard or swing arm.
Anyone with Willie & Max saddlebags in these sizes on their Dynas can help reassure me about fitment ?
Here's a couple of crappy cell pics. I like my willie & max bags but probably because I got them for a song on ebay. I thought about going with detachable hardware like barebacks but they push the bags out even farther than the regular hard mount hardware. Plus it only takes 10 minutes to switch them out. Hope this helps a little.
The plastic innertub seems rather flimsy. Anyone have other types of bags in the same dimension and price range that would be a better fit to Easy brackets ?
What about these guys from Saddlemen :
http://www.jpcycles.com/product/831-...50&results=100
As far as bags go I went with Tek leather bags,http://www.edgeleather.com/Edge-Prod...Model-101.html best bang for the buck.
These would work well for you, but they have other styles too. They have quick release too. Off and on in 30 seconds. Good luck.
I have HD bags that are about the size of the larger ones you mention, but they have notches for the turn signals. If you can't see for yourself on a friends bike I would advise measuring and calling JP or whoever's bags you are thinking about. I bought some for my wifes bike at Leatherneckjims. They sell ez brackets too. You can call them with all your questions as well.
