Using Pinch Bolts for turn signal mount
Old May 23, 2010 | 12:05 AM
turbostang's Avatar
turbostang
Default Using Pinch Bolts for turn signal mount
How recessed are your pinch bolts? On my 08 Street Bob, they are set in a good 3/8" at least, and I'm worried about trying to tighten that up againt the swivel plate. My thoughts are it'll just chew the plate and take it into the recess. Or the pinch won't be as good. Thoughts, anyone? Thanks
T.J.
Old May 23, 2010 | 02:19 AM
Wonkaboy's Avatar
Wonkaboy
I bought the Harley kit which comes with new pinch bolts and torque spec's.
Old May 23, 2010 | 03:38 AM
turbostang's Avatar
turbostang
Crap, I meant the pinch bolts for the triple tree.
Old May 23, 2010 | 06:10 AM
powerlab's Avatar
powerlab
Default bolts
jut make yourself a couple of spacers to go inside the tripple tree to take up the space..then use your stock swivel mount from the left side and on my 09 i hade to fab up one..i used the stock one just welded it to a flat piece of stock and done...simple...let me know...ill send ya some pics if need be. o and btw..dont use the stock bolts..go down and buy yourself a couple nice crome ones like 1/2-3/4 longer.....
kevin
Old May 23, 2010 | 09:52 AM
turbostang's Avatar
turbostang
Kevin,
I can't wrap my head around that. Could you shoot some pictures this way to help? Thanks.
Old May 23, 2010 | 02:15 PM
HDDyna2006's Avatar
HDDyna2006
Search the Under fifty Mods thread.
Old May 23, 2010 | 04:04 PM
8541hog's Avatar
8541hog
The only way it would depress into the recess is if you use a bolt with a head smaller than the recess hole diameter. If you are worried about that just add a flat washer.
Old May 23, 2010 | 07:27 PM
powerlab's Avatar
powerlab
Default sb
you can see on the left side you simply use your stock mount..open up the hole..bolt it on and your done.On the right side i took the stock mount and welded the swivel to flat stock..basiclly to match the other side...simple and easy...
Attached Thumbnails Using Pinch Bolts for turn signal mount-cid__0523002008a.jpg   Using Pinch Bolts for turn signal mount-cid__0523002009a.jpg   Using Pinch Bolts for turn signal mount-cid__0523002009b.jpg   Using Pinch Bolts for turn signal mount-cid__0523002018.jpg   Using Pinch Bolts for turn signal mount-cid__0523002019.jpg
Old May 23, 2010 | 10:19 PM
turbostang's Avatar
turbostang
Kevin, thanks. As I was riding into work tonight, I realized what you meant by spacer. I could just put a sleeve around the shoulder of the bolt and use the otuside or the tree as the contact point of the head. Again, big help guys. Thanks.
Old May 23, 2010 | 10:26 PM
kcblaze's Avatar
kcblaze
J and P sells a nice piece/kit that the turn signal mounts to and then replaces the existing pinch bolt. Makes a nice clean look on my 07 Street Bob. I did put a washer/spacer in to fill a little bit but otherwise they work great.
Tjroadie
2014-2024 Touring Models
Jul 16, 2019 07:50 AM
skewzme
Oct 26, 2017 11:26 PM
Jackpoticorn
Aug 25, 2014 12:23 PM
lateralus
Apr 27, 2013 10:15 PM
Scoob
Feb 26, 2008 08:09 AM
