Is it torck sockets I need and what size range?
Old Jun 9, 2010 | 10:31 PM
C908's Avatar
C908
Default Is it torck sockets I need and what size range?
Well I'm in the middle of changing out my bars and cables.I just discovered it looks like I need torck sockets. I purchased torck bits when I bought my bike but I guess I overlooked the sockets. Could someone please tell me the size range that would be good for a 2010 Wide Glide? Thanks
Old Jun 9, 2010 | 10:40 PM
HDTech74's Avatar
HDTech74
Get a whole set from t10 to t60.
switch housings are t25
master cylinder and clutch perch are t27 as is the derby cover.
T27 is a must. alot of stuff is t40
You will need some allens too both regular and ball allen from 5/32 to 3/8
Old Jun 9, 2010 | 10:48 PM
C908's Avatar
C908
Thanks for the information and sorry if I snapped at you on my other post but it's been a long day.I just want to get my bars and cables changed out so I can ride!
Old Jun 9, 2010 | 11:21 PM
Craig4711a's Avatar
Craig4711a
Be sure to buy "quality" torx sockets.... the T27 I bought from snap-on was $27... and well worth it. The cheap ones scarf up, twist and will strip screw heads. JMO
Old Jun 10, 2010 | 01:19 AM
ynots's Avatar
ynots
might want to check out what this tread has to say about Torx & Torx Plus
https://www.hdforums.com/forum/dyna-...-stripped.html
Old Jun 10, 2010 | 11:58 AM
1320go's Avatar
1320go
Smile torx
Ithink that the OP is talking abiut needing sockets not bits He said he had bits.Some replys are about bits.And also about the bit sizes HD uses torx plus screws.Standard torx bits will strip some screws no matter what quailty they are.
Old Jun 10, 2010 | 12:04 PM
Grendel4's Avatar
Grendel4
Just pull the torx bit out of the socket and stick another torx bit in it. No biggie.
Yuh, I just got through monkeying around with a T27 on my switch housing and it stripped it a litlle bit. Easy to do. But I'm pretty sure it'll be okay for at least one more R&R. Prolly. If not, then I'll have to buy another bolt the same size.
Drat.
Old Jun 10, 2010 | 12:12 PM
yellowted's Avatar
yellowted
Default torx plus
i recently picked up a set of torx plus from snapon after i snapped the tip off of my matco t40 when checking the tourque of the rear disc. i ended up ebaying a replacemet but i got a snap on t40 then ordered the plus set after some reading. the real mistake i made was using a security matco bit. either get a set of non security and be careful of get the torz plus set
Old Jun 10, 2010 | 12:25 PM
gnip's Avatar
gnip
From: Cleveland, Ohio (how do I put up with this place?)
Craftsman / Sears sell a nice complete set with the ratchet. Maybe a bit overkill but I use them for other projects too.
Old Jun 10, 2010 | 01:45 PM
1320go's Avatar
1320go
Smile torks+
I think some of you are missing the point.Torks and torks plus are different sizes.Harley uses torks plus screws.Torks will go into the Harley screws but they are a loose fit and wiil sometimes strip out the head of the Harley screws.The torks plus bits will not go into a standard torx screw.Google Torx and they will explain it better.
MorrisGray
Jun 1, 2016 09:15 AM
joemcvw1951
Nov 23, 2013 02:29 PM
BKSinAZ
Aug 12, 2012 07:23 PM
Johnny
General Topics/Tech Tips
Jul 20, 2008 06:13 PM
CMC
Nov 21, 2007 05:58 PM
