09 dyna restart
granted, that place has a filter, and keeps out the crud and particles via the filter element, but
i guaran-friggin- tee it .. pull off the filter, slip your finger back there and do a military style white finger rub, your gonna pull out a good amount of carbon, ccrud and what have ya....
i break out my carb, fuel injector cleaner spray and a damp towel from time to time. i spray the towel and reach in there and wipe it down...
if you look into the throttle body, you'll see a small hole, (* i believe its on the left ) git in there and clean it out as well
i do it once a month... and Not one problem starting her up..
Pre-ignition is the START of combustion before a spark event and the rising piston, is now compressing a fresh fuel charge. Detonation can and does lead to hot spots in the chamber, that can cause pre-ignition!
But detonation is PING and is the fuel charge exploding at the END of combustion, whereas pre-ignition is the lighting of the fresh charge before a spark event. Pre-ignition cannot be heard and is a short duration event! As it will in most instances burn a hole in the piston very quickly!
Detonation will cause damage over time and can be both "audible" (it can be heard as a PING) and low level detonation can be non-audible. (it cannot be heard.) But even low level non-audible detonation over time can cause damage to both pistons and ring lands!
Admittedly, I tend to mistakenly blur the terms, though as you describe, pre-ignition and detonation are two separate and distinct events. To me, it's like a cat chasing it's tail. I get that you can't hear pre-ignition, and that it's a detonation, or explosion or uncontrolled burn creating the "ping" you hear. Detonation can produce hot spots that can cause pre-ignition. Detonation occurs sometime during the intake (air in, fuel injects, piston moving towards BDC) stroke or compression (valves closed, piston moves towards TDC) stroke, but obviously before (pre) the power (plug fires, mixture combusts, piston heading down) stroke. See how I blur it?
Now, when you say simultaneous (1. do you mean to say spontaneous?
When you say simultaneous (2. do you mean to say spontaneous combustion? If not, what is the other event occuring simultaneously with combustion? (or detonation?) AND, just so you know, I'm not trying to be argumentative, just really trying hard to wrap my mind around your post. Cheers (Really!)
Or all at once!
spontaneous= unprompted or without a reason. Where the end gases do combust because of a the heat and pressure of combustion, so there is a reason.
So technically, simultaneous is the term you will find in engineer textbooks to explain the end gas detonation.
And yes I mean they ( the remaining end gases) combust all at the same time, in a mini explosion.
Or all at once!
It always starts eventually. At the beginning of the hot weather sometimes I would make the problem worse because my brain had become trained to the quick start the bike gave me in cooler weather and I would involuntarily release the starter button after the second revolution. It would pop out the air cleaner when I did that. Now I just hold it down until the bike really starts and it's not much of a problem.
