Sitting in traffic.
Old Jun 22, 2010 | 05:51 AM
sniper77's Avatar
sniper77
Originally Posted by HDTech74
I'll look into the EITMS.
last I knew it only came on dressers
Manual activation didn't come out until fly-by-wire, which is only on the baggers. Rear cylinder cooling (EITMS) has been around since FI AFAIK.
Old Jul 3, 2010 | 12:07 PM
ppalmerjr's Avatar
ppalmerjr
Anybody know if this feature is on the 09 Crossbones? From what I have been reading it is an optional upgrade or something like that...
Old Jul 3, 2010 | 10:50 PM
8541hog's Avatar
8541hog
Unless there is something different about Softails, yes, it has been on all EFI bikes, it may not be active on some unless you have had the stage 1 download.
Old Jul 4, 2010 | 08:19 AM
ppalmerjr's Avatar
ppalmerjr
Stage 1 download? I have the PCV installed does that count?
Old Jul 4, 2010 | 09:42 AM
sniper77's Avatar
sniper77
I'm really not familiar with the PCV but the ECM does have the ability to shut off the rear cylinder. A quick check with your dealer service department can tell you if it is enabled.
8541hog's Avatar
8541hog
No and if you have a PC you do not need the HD download.
Old Jul 9, 2010 | 08:04 PM
jimmorningstar's Avatar
jimmorningstar
How do you enable or disable? or can you.
Last edited by jimmorningstar; Jul 9, 2010 at 08:07 PM. Reason: left out something
Old Jul 10, 2010 | 09:24 PM
parts eeter's Avatar
parts eeter
Default My 06 does it
My 06 with the Fuel Pak does this. The first time I heard it over a year ago it alarmed me. Now I wish it would idle that low all the time. Sounds better.
I learned something new here so thanks to all.
Old Aug 1, 2010 | 02:55 PM
sober89's Avatar
sober89
Stage I
Default engine idle
if your bike is equiped with a eitms sensor that is a good thing.what it does is if the engine gets hot the rear cylinder will get less spark and the cylinder will stay cooler and the rpm will come up a little and the bike almost sounds like a 2 stroke.If you nudge the throttle it will go back to normal for a few seconds then back to 1 cyl.This is usually put on 96 cu.in and larger but Ive seen it on smaller.I changed my exhaust on my 09 fatboy to black shortys from samson and the dealer suggested I have the eitms installed.$210 includeing labor.The bike sounds good and doesnt spit fuel out the filter and evened out the tone.It starts easier too.The first time I heard the engine pitch change I thought I lost a spark plug wire.I also picked up a few more miles to the gallon.Hope this helps
sober89
Hogdoc45
15
Nov 15, 2018 07:21 AM
Bogart999
Apr 3, 2015 09:24 AM
ptl203
May 21, 2014 05:44 PM
jkoch
Jul 17, 2012 05:42 PM
dbcoooper
Sep 19, 2009 06:56 PM
