Active Exhaust Control - how to deactive
Old Oct 2, 2013 | 01:51 PM
  #31
Foxster's Avatar
Foxster
Originally Posted by sacchino
u sure u cannot reading into sepst files and guides seems is possible...
Well, it might be there but I've never seen it. Where does the files and guide say it is set?
Old Oct 2, 2013 | 02:55 PM
  #32
oakspeed's Avatar
oakspeed
i did mine by unhooking the retaining spring, opening the valve, and locking it in place with a split pin, after drilling 2 small holes to put the pin through.
no warning lights have come on. the best way would be to cut out the valve assembly, then weld the pipe back up, but i did it the easy way.
Old Feb 9, 2014 | 03:35 PM
  #33
Niels83's Avatar
Niels83
I have a 2014 FXSB Breakout with a screaming eagle heavy breather-kit on it and thus used TTS' DHA358-01 tune-file.
I live in Europe and thus have the "Active Exhaust Control"-valve on my bike that shuts my rear muffler at certain points. I hate that and want to have it open at all times. So I've "disabled" the Active Exhaust Valve when I updated my ECM via TTS MasterTune (as an option during the tune). But the valve remains closed. Do I need to enter something in the tune to have it open all the time? Or do I need to physically force the valve to remain open and the tune only prevents the error-code?
Edit: I just looked into the software of the tune and found these extra options under the "Table selection" menu:
Active exhaust Control 1st gear
Active exhaust Control 2nd gear
Active exhaust Control 3rd gear
Active exhaust Control 4th - 6th gear
I'm guessing these values are where the valve should be opened or closed. Based on what I see here, I'm guessing 100 is fully closed and 0 is fully open. So to have the AIC-valve open at all times, I guess I need to change all values from anything to 0? Here's an example of what I did (I selected the "Active Exhaust Control 2nd gear" under the "Table selection" menu for tile DHA358-01 which is for a 2012-2014 softail with an open air filter):
So I update the ECM with this altered version of the DHA358-01 tune-file in which these AEC values are all set to "0" and choose enable for the Active Exhaust Control? I think "enable", since the ECM otherwise disregards these values, right?
Old Jul 30, 2014 | 12:21 PM
  #34
Frédéric CM's Avatar
Frédéric CM
Does someone has more infos about disabling the valve on 2014 dyna via the SE software ?
It seems possible for older model, but the option seems not here on 2014 maps...
Old Jul 30, 2014 | 12:37 PM
  #35
Foxster's Avatar
Foxster
Its not possible on the older models either.
Old Jul 30, 2014 | 11:50 PM
  #36
Frédéric CM
with older models dyna/softail (until '13), you can do it with the Supertuner software there is an option : go to "Tuning Setup", then there is a tab for "Active Exhaust" (and Intake) there you can disable it
But the tab is not there for newer models dyna
Old Jul 31, 2014 | 02:53 AM
  #37
adm's Avatar
adm
This won't help you much, but you can also disable it using a Power Vision tuner.
Your other option is to physically disable it as Foxster posted previously. You can remove the motor and cable, then fix the valve in the open position.
But for my money, you are better repaving the whole exhaust anyway. Get rid of the catalytic converter and the AES at the same time.
There's also the Active Intake to consider as well if you have that fitted. My bike didn't have it (UK), but other countries might....
Old Jul 31, 2014 | 12:50 PM
  #38
Frédéric CM
Didn't have the active intake too...
I'm going to fit a US rear pipe (without valve), alreadu have a set of V&H slipons so no cats
I'll remove the motor and put an AES bypass module so no error codes... but I still looking for a way to do it without having to put a bypass, like on US models...
Old Aug 10, 2014 | 06:25 AM
  #39
Frédéric CM
What brand of AES bypass do you guys recommands ? Some seems not waterproof...
Old Aug 11, 2014 | 03:23 PM
  #40
micioflavio's Avatar
micioflavio
I am going to do it with the power vision, this is the answer i had from Dynojet:
You can somewhat control the operation of the AES in the tune, but I believe most people just disconnect the wire to the unit, when the valve is fully open; then turn it off in the tune. That way the valve is always open.
so I guess it is the same thing with the plug, you just disconnect the aes when open and then put in the plug, so it should stay open.
