Extended Headlight Mounting Block
Old Aug 1, 2010 | 07:58 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Originally Posted by masterblaster
That one is what I am looking for but it says ears have to be 1/2" and the 09 has 3/4 inch ears on the housing. What year was that WG mounting block from? Thanks Howard.
1/2" is the width of the mounting or the width of the mounting block/same. If the width between the "EARS" of the headlight or the width of the mounting block is 3/4" than this mounting block will not work. A simple measurement will do. I have one that is going onto my hardtail so you can try it out first if you like. I do not like it but have to use it on my Hardtail due to fitment problems and it is also long and low. A real POS in my opinion but it had a larger and expensive donor motor.
Old Aug 1, 2010 | 10:16 PM
pcbunn's Avatar
pcbunn
In prep for a Ness fairing for my WG, I will need to raise my headlight about 2 inches and now I'm wondering if the wiring will reach. Does anyone know how much slack is in the headlight loom?
Old Aug 1, 2010 | 11:00 PM
Baeseman1's Avatar
Baeseman1
Wasn't enough in mine & I didn't want to pull out the main harness and have THAT much slack hanging there just for the headlight. I added to the length inside the headlight bucket.
Old Aug 2, 2010 | 02:56 AM
maddog76's Avatar
maddog76
I like the look of the headlight being extended a little, thinking about doining it to mine.
Old Aug 2, 2010 | 04:38 AM
masterblaster's Avatar
masterblaster
This sounds like a job for SooS
nickdandrums
General Topics/Tech Tips
Jul 25, 2019 08:08 AM
Sp1d3r
Apr 17, 2018 07:46 AM
HD_Matt
Dec 19, 2016 03:57 PM
ironhead tommy
Ironhead
23
Apr 15, 2013 10:38 PM
lhcstreetbob
Jun 27, 2009 09:05 PM
