What is this connector
Old Aug 31, 2006 | 02:15 AM
RMBob's Avatar
RMBob
Default What is this connector
I just replaced my A/C on my 06 Bob with the Arlen Ness Big Sucker. When I took off the stock A/C there was a cable that was clipped into the bottom of the stock A/C housing, but was not connected to anything. Because there is no where on ther Big Sucker backplate to clip this wire I just zip tied it out of the way. Does anyone know what this cable is for?
Old Aug 31, 2006 | 11:33 AM
WgSkee's Avatar
WgSkee
Default RE: What is this connector
mvlow... Not to be a pain in the butt.. But, do a search you'll find all you need to know about the connector..Peace..Skee
Old Aug 31, 2006 | 11:50 AM
Whiffleboy's Avatar
Whiffleboy
I'll make it easy for you since searching almost gives you too much information...
If you live in America, you won't need that thing. That's all you need to know.
Whiff
Old Sep 1, 2006 | 08:13 PM
soup48's Avatar
soup48
I think it's for Californa bikes.
Old Sep 1, 2006 | 09:28 PM
DougsDyna's Avatar
DougsDyna
It operates a solenoid in the air box.
That unit is called the Active Intake Solenoid. It's purpose is to open an air valve in the air cleaner at speeds over 70KPH, with a throttle opening greater than 50%. It is for international models (HDI).
Reference: HD service manual pages 4-3, 4-7.
Hope that answers your question.
DD
Old Sep 2, 2006 | 12:21 AM
TowJam's Avatar
TowJam
On my bike, it keeps coming unfastened from the socket. No matter how securely I think I've got it pushed into the socket, I'll find it hanging out from under the airbox after a "spirited" ride.
Swear to gawd... first time I saw it hanging down I thought my L'rider had come equipped with a tampon.
Old Sep 2, 2006 | 12:46 AM
WgSkee's Avatar
WgSkee
Geeezzz Guys... This post is on the same subject, read [sm=confused06.gif]below...
Air cleaner-loose solenoid wire after a/c install
Old Jun 2, 2008 | 04:44 AM
kuleli's Avatar
kuleli
hi guys,
I live in europa. and have 2006 wide glide. So I have the same problem. What should I do with this cables ? I bought se a/c but cannot install because dealer does not know what to do w
th this cables ? may we zip tie it behind the new back plate ? I am afraid to see error code....
helps are appreciated
06 wg hdi
Old Jun 2, 2008 | 06:55 AM
murphdog's Avatar
murphdog
If you live in Europe, you'll need something like this http://www.vtwinmania.co.uk/product_...oducts_id=1314
There's also a Dynojet version of this in the Zodiac online catalog. If you have a SE Race Tuner, you can disable it there.
Old Jun 2, 2008 | 07:42 AM
BULLDOG88's Avatar
BULLDOG88
Mauldin. Does it still have the great wall of china?
