Tail lights burning out
Old Oct 21, 2010 | 06:27 PM
parts eeter's Avatar
parts eeter
On a previous build I did, I had to use a mount that was a bit more rigid than the stock setup and I had the same problem. I ended up changing the bulbs to LED units and never had to replace it again after 8 years I sold the bike with the same bulb in it. The standard bulbs would last maybe 1 weekend if lucky. Hope that helps.
Old Oct 23, 2010 | 04:30 AM
ply72rr's Avatar
ply72rr
Originally Posted by Cowpokey
I'm quite the outlaw! At least you didn't get any tickets in the mail from me driving in the bus lane with your truck...did you?
Why? Should I be expecting some...lol.
So far I got one ticket out of the three photos that I received.
Old Oct 24, 2010 | 02:09 AM
mahagowitz's Avatar
mahagowitz
same thing was happening to me, a bulb every month or 2. After 2 years of it I replaced the socket for it, a couple bucks, and it hasn't burnt out yet. The old socket wasn't a real tight fit and it seems the bulb had enough wiggle room to vibrate the filament apart. It almost looks like it was a bit melted on the inside, I think I saved it but would have to look for it.
Old Oct 24, 2010 | 04:37 AM
Jarhead08's Avatar
Jarhead08
Maybe lower your fuse size so it blows before your bulbs?
Old Oct 24, 2010 | 11:57 AM
parts eeter
Just take a picture of the $$$ and send that in!!
Old Oct 25, 2010 | 12:58 AM
Cowpokey's Avatar
Cowpokey
No, I only drove on base. I do have to be careful though, with the parking tickets my wife got, and the speeding ticket I got driving your truck I'm close to the limit for the last 12 months.
I'll have to try that. It's the same side, burned another one out this weekend. Mine looks a little melted too.
Old Oct 25, 2010 | 02:48 AM
Smitty79's Avatar
Smitty79
I'm having the same problem with my 09 SB. The right rear turn sig bulb keeps burning out. I also have the sig relocation kit on for my detachable sissy bar. Good info, hopefully I can get mine straightened out.
Old Oct 25, 2010 | 06:51 AM
JohnnyC's Avatar
JohnnyC
Toasting bulbs could be a voltage regulator issue. You'd think if that was the case they all would take a hit.
Vibration / Shock has a lot more to do with the problem I would think.
If moisture gets into the base the corrosion will cause issues like blowing bulbs.
I agree with replacing the bulbs with LED lights.
I recently bought a bike that has extra brake lights, 6 bullets to be exact. When I hit the brake it would pull the battery down below the safe level. Set at a light with brake lights on and it put a strain on the 22 amp recharge system originally in the bike. I changed that out with a 32 amp system and 6 - $8 LEDs and the problem solved. I've been looking at LED turn signals next.
By the way if you use LEDS in the typical H/D bullet holders you have to pry the base up slightly or they short out. The LED housing is almost as big as the inside space and that pushed the center HOT contact touching the housing. A little adjustment with a pair of needle nose pliers and all is good.
Plus the LEDs last almost forever.
Old Oct 25, 2010 | 08:09 AM
Cowpokey's Avatar
Cowpokey
mine is the right side every time.
Jlovesseconds
Jun 15, 2014 08:15 PM
russl179
Oct 28, 2010 08:20 PM
r8rs4lf
Jul 22, 2010 10:24 PM
oldmsocko
Jul 29, 2009 09:47 AM
dukmn80
Jun 9, 2006 05:34 PM
