Jack for 06 Wide Glide
Old Sep 19, 2006 | 05:39 PM
grueter's Avatar
grueter
Default Jack for 06 Wide Glide
HELP Has anyone found a jack that will work on a 06 Wide Glide? Tried a Sears yellow one (hits the oil pan) Tried a Kobalt from Lowes (The span is still not wide enought to clear underneath) will work on 05 Dyna and older but not 06 Wide Glide Thanks for any help.
Old Sep 19, 2006 | 06:14 PM
gman's Avatar
gman
Default RE: Jack for 06 Wide Glide
i have a '06 wg also. i use the aluminum one from sears, with the HD adaptor kit for the late WGs. works like a dream. without the HD adaptors (they are just some poly blocks that temporarily attach to the frame of the bike) the jack hits the trans pan as you mentioned.
Old Sep 19, 2006 | 06:49 PM
misfit's Avatar
misfit
What ever one you use, HD, Sears, or brand X, you will need to purchass the dyna adapter kit, because of the oil pan. I have the HD with the kit and it works great.
Old Sep 19, 2006 | 10:07 PM
soup48's Avatar
soup48
I have purchased a jack from a company called Northern Hydraulics. If you canget to it go to the ATV section in the catalog or go to their web sight, I thinks it's www.northenhydraulics.com.
Old Sep 19, 2006 | 11:19 PM
CoolBreeze3646's Avatar
CoolBreeze3646
I bought the cheaper Sears Red color Jack on sale for $69.99. I used three hock pucks for adapters, they work just fine and keep the bike steady on the jack. I learned this trick while working on my corvette as the jack points require adapters and hockey pucks are just fine, just the right stiffness and just the right size and price.
Enjoy,
The Breeze
Old Sep 19, 2006 | 11:20 PM
CoolBreeze3646
I bought the cheaper Sears Red color Jack on sale for $69.99. I used three hockey pucks for adapters, they work just fine and keep the bike steady on the jack. I learned this trick while working on my corvette as the jack points require adapters and hockey pucks are just fine, just the right stiffness and just the right size and price.
Enjoy,
The Breeze
Old Sep 20, 2006 | 01:07 PM
malcolm06WG's Avatar
malcolm06WG
I bought the J&S jack for my 06 WG and it works fine. You can jack up the bike and roll it around your garage as you need to. In fact I almost rolled my bike into my car. The jack is very well made and works good. Other guys have written about them on this site.
jsjacks.com
Old Sep 20, 2006 | 02:09 PM
Bigbird's Avatar
Bigbird
Where do you buy the adapters for the Dyna?
Old Sep 20, 2006 | 02:37 PM
SUPER01's Avatar
SUPER01
You can get them from your dealer or Online HD here.
Old Sep 20, 2006 | 04:34 PM
bobcowan's Avatar
bobcowan
I've been using a Dunwell lift for quite a few years. Only 4" when collapsed. Very sturdy and stable.
The only "adapter" I need for the new bike is a spacer. If you look at the bottom of the frame rails, H-D welded a small tab to the bottom of the right frame rail to protect the oil pan. But they didn't weld one to the left rail. So you have to use a spacer on the left side to compensate. I have some plywood that I use for that.
Paddygfw
Jul 2, 2019 06:47 PM
2of2
Feb 2, 2008 11:02 PM
bsk116
Jun 27, 2007 11:36 PM
brubo
Jun 26, 2007 08:37 PM
gto frank
Aug 15, 2006 08:28 AM
