+1 on bolt depot. They have everything Ive ever needed. Usually I go to Ace first, it they dont have it I go to Bolt Depot. Ive tried Home Depot, Lowes, and even a speciality bolt store and finally settled for the above 2 choices.
Ive done a nut and bolt full restoration on a 68 Triumph Bonnie using Ace and Bolt Depot for all my fastener needs (including 7+ inch engine mounting bolts in Stainless Steel.)
I had a 71 Bonnie when I got out of the Army years ago. I bobbed it with a Sportster style tank, 8" dogbone risers and drag bars, and 8" extended front tubes. That was nice bike for the money. Had a lot of good times on it.
Originally Posted by soft 02
Wow they carry british bolts too. I've always had to swap them for SAE.
good catch Soft 02! No, none of the regular places stock Whitworth or BSF etc. I too changed out all the British stuff to SAE. Everthing on my Bonnie is now SAE except the engine bolts and some odd stuff like the tach mounting bolts and sprocket fasteners. The 68 was a cross over year for threads and about 50% of my bike was already SAE by that time.
Yea I forgot that they are called whitworth. Oh well. I wouldent mind getting my hands on a BSF tap and die set as I have a mill and a lathe.
These guys are in England and have every nut and bolt in stainless steel for just about all vintage British bikes. Theyve even custom made some bolts for me:
Well I talked with a structual engineer on the bolt grade thing and my Dyna motor mount scenario. He told me he could not comment on it professionally without cad specs of load and angles etc.
But he said off the record from the info I gave him a grade 5 would probably be sufficient, but if possible go with equal grade of the OEM (grade 8)
But also he brought up (and questioned me on) an aspect besides the Tensile strength ratings that I was inquiring about. That is torque ratings. He asked me what the OEM torque was on the bolt. He said that beside tensile and axial loads, bolts have to qualify in the torque strength range. He said
the recommended torque specs on said bolts were
3/8" dia. 16 tpi = 15 to 17lbs @ grade 2 (grade for many stainless)
" " = 23 to 26lbs @ grade 5
" " = 33 to 37lbs @ grade 8
--As you all know the HD torque spec for the front isolator mount is 21lbs min.
He also said that torque failures (depending on variables) usually occur anywhere from 22lbs to 35lbs over recommended torque, which agrees with scenarios I have experienced myself when accidentally over torqing something. (yea once a long time ago I grabbed the ft lb wrench for an inch lb rating, I had a case of stupid that day, always double check which wrench now)
Just thought I would share that.
