kickstand removal question
Old Jan 26, 2011 | 12:01 PM
Flyer6440's Avatar
Flyer6440
Default kickstand removal question
I have a 97 Super Glide and my kickstand is in need of rechroming but I'd like to know the best and easiest way to either removing the entire assembly or just the stand itself. If you think just the stand, whats the easiest way to get to the bolt holding it on. It's on an angle that makes getting a wrench on it almost impossible. If I should remove the entire assembly, whats the trick to that. My bike is on a lift right now, Many thanks
Old Jan 26, 2011 | 12:10 PM
HOG_0308's Avatar
HOG_0308
remove your floorboards taken five min job, and then you will have access to the stand. remove the bolt on top of the assembly first should be a 1/2 inch. Then push the stand all the way forward to the front of the bike, this will allow you to take the spring off. then the stand just slides out from under the assembly.
Old Jan 26, 2011 | 12:37 PM
JRK5892's Avatar
JRK5892
as stated above... i hit mine wiht some de greaser first to remove the road grime... then i coated mine in black... looks way better!
you can see it here
Old Jan 26, 2011 | 12:41 PM
TXCHOP's Avatar
TXCHOP
you can see it here
Yup, Joe has mine now. Black looks cool on kickstands!
Old Jan 26, 2011 | 02:01 PM
Flyer6440's Avatar
Flyer6440
Default Kick Stand removal
I am able to get at the bolt at the top of the stand, tried to turn it, won't turn, should I just power turn it til it finally breaks free? Who ever said taking a bike apart would be easy Thanks for the help so far, any new suggestions would be greatly appreciated
Old Jan 26, 2011 | 03:49 PM
07bobber's Avatar
07bobber
swearing and hollering usually does the trick for me when somethin im wrenchin on is bein a pain in my a$$...try that
Old Jan 26, 2011 | 04:14 PM
bcmiles's Avatar
bcmiles
Old Jan 26, 2011 | 05:18 PM
bobnehoc's Avatar
bobnehoc
If swearing and hollering doesn't work get some liquid wrench and soak that sucker....Let is sit for a little while and give it another try....
thanantos
EVO
Sep 13, 2019 09:21 AM
Mchad
Jul 19, 2017 07:09 AM
Principle
General Topics/Tech Tips
Mar 20, 2016 06:25 AM
Yldtang
Mar 18, 2010 04:47 AM
Sando
Jul 14, 2007 01:48 PM
