Stage 1 Question
Old Feb 3, 2011 | 08:30 PM
  #31
Zac Strayer's Avatar
Zac Strayer
Originally Posted by SURFOR Chop
Welcome aboard to the OP (original poster) ...
As explained by a couple of the fellas, Stage I is a 'high flow' air cleaner (sometimes, A/C) and less restrictive exhaust. Since the motor is an air pump of sorts, and your bike is an electronic fuel injection (EFI) system, when making the changes, the computer (electronic control module or ECM) program is not designed to account for the additional air flow. As a result the air to fuel ratio (or AFR) will be lean--more air with the same amount of fuel. This condition increases the heat generated by your motor and is otherwise not good for your bike.
Harley Davidson, through their 'performance' brand name Screamin' Eagle (SE) realizes owners will frequently make this combination of modifications (mods) and will reprogram your ECM to enrich your AFR curves. This increase in fuel and air at the same RPM will increase performance as measured in terms of Torque and Horsepower ... but, will also decrease your average fuel economy a little.
The service manual--while extremely handy (and which I heartily recommend)--does not really cover this information.
In addition to SE 'download' reprogramming for your ECM, there are a plethora of alternative solutions to a lean AFR condition many provided by the aftermarket. SE makes a couple of popular solutions--one is an 'add on' or 'piggy back' module and one is a software system that allows you full on access to reprogram your ECM (not only for the AFR, but for the timing advance curve). Various popular aftermarket systems are Power Commander (PC ... various gererations from III to V currently), Vance and Hines Fuel Pack, Kuryakyn has one, Dobeck, and so forth.
A vendor who used to supply Harley Davidson with the Screamin' Eagle Race Tuner (or SERT) is TTS Master Tune. They now offer a competitive full access ECM programming system. Another popular full ECM replacement system with the ability to fully access and tune is Thunder Max with Auto Tune (T-Max, or sometimes TMAT) there are a few others as well ... I believe Accel makes one, FI2000, etc.
When going with a 'Stage I' motor setup, it might be considered 'overkill' to get a full ECM programming system as they tend to cost from around $450 - $850 range ... however, if 'Stage I' will just be a phase you are going through ... until you save up enough for your cams, heads and big bore kit, then it might be worthwhile making that investment 'up front' ....
Good luck and hope this info makes your decision a little clearer ....
R/
'Chop
Thanks alot for this info, it helps out alot for me to understand but also has shown me i have alot of reading up to do on this subject. glad i dont plan this for atleast the first year of riding. it'll give me time to learn before jumping in it.
Old Feb 3, 2011 | 11:56 PM
  #32
USMC2010's Avatar
USMC2010
I had my changes added during my initial break in service. I am happy with the performance other than the fact the newer bikes run a lot hotter than my 2000 softail did.
Old Feb 4, 2011 | 05:50 AM
  #33
gd55's Avatar
gd55
So a Stage 1 requires SE parts only.
Would they be able to do it with the stock exhaust and a SE breather
giving me a chance to get better slip ons later?
Just wondering.
Old Feb 4, 2011 | 06:33 AM
  #34
Junior in NE's Avatar
Junior in NE
Stage 1 seems to help some with that.
Old Feb 4, 2011 | 08:57 AM
  #35
carltex's Avatar
carltex
Just wondering.
No, stage 1 does not require SE parts only. Stage 1 is considered any brand hi flow air cleaner and often, but not required, aftermarket exhaust, be it slipon mufflers or full exhaust system.
Yes, the changing of the intake is what matters as far as Air Fuel Ratios go. You can do that and add the pipes later if you wish.
The SE part only comes in if you get the dealership to do the stage 1 download. Often times they will only deal with Harley products claiming it will affect your warranty.
Old Feb 4, 2011 | 09:37 AM
  #36
Slim_B_Kool's Avatar
Slim_B_Kool
Thumbs up
I agree with that somewhat but some dealers deal with aftermarket parts and doesn't void the warranty. I had my stage 1 done at the dealership. I had a SE air filter, SE race tuner, but they put V&H competition series 2-1 exhaust on my bike. It just depends on the dealer and what parts they like do deal with. You can have the dealer do stage 1 for you if you haven't already got a bike and have it added to your loan. You can go with just slip-ons like S&S or Rush but with the stock ECM you need to keep your baffle around 1 3/4 inch or less. Anymore and you can run into tuning issues with the ECM.
Old Feb 4, 2011 | 09:43 AM
  #37
PoCoBob's Avatar
PoCoBob
I can only tell you what my dealer told me. I had the a/c and download done first (as noted above). My dealer told me that I could put any type of pipe on I wanted to. As long as the engine stayed stock the download could handle any pipe. I'm not saying that's right, but it is what I was told.
Wide Open Cycles
Milwaukee Eight (M8)
20
Sep 23, 2017 04:51 PM
PyroMedic
May 6, 2014 07:24 PM
bezoar
Jan 4, 2008 05:12 PM
Devil Dog
Nov 9, 2006 01:11 PM
stewart1962
Feb 15, 2006 01:01 AM
