CART / SERT question & BCT install
Old Oct 5, 2006 | 09:06 PM
chukmar1's Avatar
chukmar1
Stage I
Default CART / SERT question & BCT install
I just put in the BCT baffles for the SEII's on my 06 FXDWG. They sound great and it could just be my imagination, but the scoot seems to really have more ooompfff! My question is after reading a number of other posts (I'm a bit confused) - what is the difference between a SERT and a CART? When I bought my WG last year, I got the SE AC and the Cart (p/n34239-06) installed. I'd appreciate any clarification. Thanks.
Old Oct 5, 2006 | 09:16 PM
SPECIAL ED's Avatar
SPECIAL ED
Default RE: CART / SERT question & BCT install
I don't really know what a CART is but the SERT is an acronym for Screaming Eagle Race Tuner it's basically an interface between your PC and the fuel injection electronics on your bike.It allows you to custom tune the FI for any number of combinations of intake and exhaust changes.
Old Oct 6, 2006 | 02:26 AM
wlbowers's Avatar
wlbowers
ORIGINAL: chukmar1
A SERT allows you to modify a map and flash it to the ECM. Modify the map again and flash that, Modify again, well you get the idea, as many times as you want.
Once it is hooked up to a MC and talks to the ECM it cannot be used on any other motorcycle.
The CART is a map that is preset for a certain muffler and or air cleaner setup. It is flashed to the ECM one time. The cart can't be used again. The map can't be modified before or after it is flashed to the ECM. If you add more equipment you have to get another CART
HDF Tech
Mar 29, 2013 02:58 PM
supernova
Apr 27, 2008 05:31 PM
jasonfish
Nov 20, 2007 10:57 AM
Indianspringsaz
Sep 29, 2006 05:46 PM
Smittyjf
Sep 6, 2006 09:42 PM
