Welder advice
Old Feb 19, 2011 | 03:14 PM
kmealp's Avatar
kmealp
Default Welder advice
Ok I would like to buy a little mig welder for projects, looking at the 115v range welders. Does anyone have a eastwood, hobart, nothern, or any other brand and how much do you like it. Yeh its not directly bike related but it will be used for bike projects and most advice I get here is good.
Old Feb 19, 2011 | 03:27 PM
Tat2u's Avatar
Tat2u
Tig welding is the go for bike projects
Old Feb 19, 2011 | 03:31 PM
redrubicon2004's Avatar
redrubicon2004
I dont know of many tig welders that run on 110 or can be had for a similar budget.
That being said. I have a 110v Lincoln electric and for a little machine, it works very nice.
Old Feb 19, 2011 | 03:36 PM
Supermachine's Avatar
Supermachine
i have a lincoln sp135+ ran about 700 new with a big bottle and cart etc..
try to buy the best welder you can afford, it's one of those tools that will outlast you
lincoln, miller, hobart all good machines
i wish i woulda went 220. mine car weld up to about 3/16 with no problems.
Old Feb 19, 2011 | 04:05 PM
Uncle Larry's Avatar
Uncle Larry
Good advice! A Lincoln or Miller will probably outlast you. This is definetely a case of "You get what you pay for". I used a wire feed in my trade almost every day and the Miller never failed me!
Old Feb 19, 2011 | 07:31 PM
greenstreetbob's Avatar
greenstreetbob
I have this also, minus the bottles. It's about the best you can do on a 110V outlet.
Old Feb 19, 2011 | 08:14 PM
Just Enough's Avatar
Just Enough
I have owned a Lincoln SP180 MIG for 20 years (220 volt plugs into the dryer outlet), use it all the time, never had one lick of trouble. I call it my metal caulking gun.
Old Feb 19, 2011 | 08:29 PM
tlb's Avatar
tlb
I have a wirefeed lincoln, 110V model. It works fine.
Old Feb 19, 2011 | 09:35 PM
ghostrider69's Avatar
ghostrider69
I have a Hobart Handler 140 and a Hobart Champion Elite. I have used that 140 more times than I can remember with no problems what so ever. Hobart is top of the line right along with Lincoln and Miller. As a matter of fact when you buy a Hobart it will have Miller parts all over it. For example the Hobart mig welders such as the Handler 140 comes with a Miller gun. One think to know though. Don't waste your time welding with the flux core wire. Go ahead and get a bottle of the appropriate gas for what you will be welding and weld with solid wire.
Old Feb 19, 2011 | 10:59 PM
lo-rider's Avatar
lo-rider
1st, don't limit yourself to 115V--get a 220V machine.
And consider a TIG/stick welder, instead of the MIG, much more versatile and capable of much better looking welds, especially on thinner materials. The newer briefcase-size inverter-types are way more efficient. Either way, you (generally) need to spend $1,000, or more, for a good used one. If you just gotta have MIG, the Miller 251 is a benchmark, and can sometimes be found used for ~$1,000-$1,500. In TIG, there are some under-$1k imports that have received good reviews. Eastwood?? Northern?? Avoid the HF crap. Seek: Miller, Lincoln, Hobart.
Check some of the welding forums.
