*Need Help.. 2007 96cc Big Radius Stage-1 Map Request
So my bike is at the dealership. They talked me into the screamin eagle pro race tuner. I currently have 2-2 V&H Big Radius pipes with smartonze quiet baffles, along with a screamin eagle stage-1 air cleaner. The dealer told me they were going to put the best map in they thought would match my set up. That may be fine, but my bike will still run hot and closed loop will remain the same.
Since the pro tuner is rather new I'm afraid there's a shortage on maps. I am looking for a map that is tweaked for closed loop, open loop, timing etc.. from someone that has a similar set up as mine. Would anyone here please allow me to use there custom tweaked map. It would be greatly appreciated. If so, I would also like to know what was changed and if you dyno it what the trq/hp and a/f ratio was. Thanks.
I'm guessing that smart tune won't adjust the closed mode clb to make it richer, and if so, only within the computers lean range of 14:1 to 14:7 and I dout 14:1. Would I also first need to manually set all the closed mode values to .798? As posted elsewhere so the computer will keep richening closed mode as much as it can due to the narrow band o2 set up. So .798 in smart tune as well should get me to 14:1?
I wish there was a way to type in a target a/f ratio in closed/open/both, say 13:2 to 13:5 open, 13:8 closed and then let smart tune adjust it to that?? Sorry, I'm kinda confused??
Look, do as Foxster suggested. Smart Tune will adjust your VE tables and you can set whatever AFR you want in the AFR table.
Some people like to screw around with the CLBs thinking they can somehow make the system self tuning, but I think the intended use of the CLBs is to adjust the sensor switch point for various fuel blends.
I wish someone had a tweaked map to try..
Anyway, for closed loop, you aren't gaining the performance boost of getting the AFR down to 13.0-13.5:1 as you would for open loop. To drag the closed loop operation down there too is just a waste of fuel. Getting it down around 14.2-14.3 or so will cool the engine and improve idling but without ruining the MPG.
I got a really nice flat AFR of around 13.5:1 when loading the engine, giving an excellent performance boost over stock with the SEPST and stage-1 hardware. I used the 176AE106.dt0, tweaked the CLB values to ~650 and then did three long SmartTune sessions. Didn't need to touch the open loop values at all.
