Fork bag users beware
I had to use some washers, but just use those bolts to hold in place.
Make sure that you don't have the bag yup against your forks and you will not get scuff marks.
My brother has had his on for a several years withno problems.
Also make sure it is high enough to not hit the fender, but even if it would touch, the bag can compress some.
It's just a welded shed hinge...i mounted it and tilted it to the angle I wanted and then welded it in place.
It is sturdy and no ties to come undone or scuff away at your forks.
