5 steps forward, one (big) step back
Old Mar 9, 2011 | 05:23 PM
USMAMule's Avatar
USMAMule
Default 5 steps forward, one (big) step back
Ok.. I am what seems like an inch from finishing up my winter mods. Switched out my chrome console for a black one from a FXDB (found GREAT info on moding up the console to fit my bike here), relocated to the forks and replaced my front signals, changed grips, and replaced the stock levers with trigger levers....and there seems to be that last inch.
To change the levers - I had to disconnect the clutch cable - and getting the tension off required completely loosening the clutch cable. I thought I had it adjusted correctly, grabs at the right place etc...Only one problem: on road testing - can't shift past 2nd gear. Closer inspection reveals that the lever doesn't "return" after up shift. So when I try to shift up again, it's got nowhere to go. If I try to gently push the lever back down, it of course goes into neutral.
One last thing, though I doubt it's related. I dropped the bike on the left side in a very low speed spill. Rear tire found some sand in a turn on me.
ARRRRRRGGGGG......
What could I be doing wrong?
USMAMule
Old Mar 9, 2011 | 05:27 PM
greenstreetbob's Avatar
greenstreetbob
loosen it all the way and make sure it is sitting in the detent the way it should.
Old Mar 9, 2011 | 05:31 PM
misfitJason's Avatar
misfitJason
Its binding somewhere or it pulled out of the ball and ramp assembly underneath your tran side cover
Old Mar 9, 2011 | 05:33 PM
misfitJason
Or it's not adjusted far enough out. You want a definitive answer post some pics of the hand control where the cableeets, and the cable routing. Also I just thought of this but your cable could be snapped
Old Mar 9, 2011 | 06:04 PM
JRK5892's Avatar
JRK5892
agreed either not adjusted right or your cable is bad, check the routing so that it is not pinched
Old Mar 9, 2011 | 07:05 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The ball and ramp could be the culprit, but the pipes you have don't they cover the clutch cable over on the right side? You could have a job on your hands.
Old Mar 10, 2011 | 07:38 AM
USMAMule's Avatar
USMAMule
Default Thanks fellas!
Thanks a LOT fells. Unfortunately it will be a little bit before I can check into your suggestions, as I am leaving for ten days today for Lithuania w/ my SO who's from there. I like the sound if binding, well I don't "like" it, but it makes more sense than a broken cable. Cables seem like things that either work or don't, not just for two gears.
God I hope it's not the ball and ramp. I will check out your suggestions when I return.
In the mean time ride safe and thanks again for all your helpful hints and comments.
USMAMule
Old Mar 10, 2011 | 07:49 AM
trip20's Avatar
trip20
Did you adjust the clutch basket behind the derby cover after you loosened tension on the cable? Or have you only loosed and tightened tension on the cable by the down tubes?
Old Mar 10, 2011 | 08:28 AM
USMAMule's Avatar
USMAMule
I only adjusted at the down tube. Something tells me I f'd up?
USMAMule
Old Mar 10, 2011 | 08:36 AM
trip20's Avatar
trip20
Yes you have to adjust the clutch behind the derby cover when ever you relieve tension on the cable with the cable adjustment nuts. Someone can correct me if I'm wrong here but I bet that's your problem.
This video how to adjust clutch pack (behind derby cover).
http://www.youtube.com/watch?v=Zl92wwLiNwE
This video shows how to adjust clutch cable.
http://www.youtube.com/watch?v=iiC5d...feature=relmfu
