How low can you go... Comfortably
Old Apr 14, 2011 | 03:03 PM
DYJ's Avatar
DYJ
I'm 220 and the wife is 110. I lowered mine the first summer I had it and with in 3 weeks put the stock shock back on. I would not suggest it if you do ANY two up riding.
Old Apr 14, 2011 | 03:09 PM
jpace024's Avatar
jpace024
Go with air ride. Dump the air to slam it riding solo, pump it up for riding 2 up.
Old Apr 14, 2011 | 03:20 PM
8541hog's Avatar
8541hog
Originally Posted by bouch42
That's great! And dropping that kind of weight is pretty impressive too.
I'm just 5'6" with a really short 27" inseam, not looking to lose any weight (quite the opposite). I just put a new front end on (3 degree, 2 over) so that should have kept the front around the same height. I forgot to compensate for the 21" wheel over the 19" I had so I'm an inch higher up front and now looking at possibly bringing the rear down... Partially for look and partially to stand flat footed.
I seriously doubt you gained an inch of height, most 19 and 21" tires I looked at when I swapped were within 1/2" of each other diameter wise. My 19 was actually only 1/2" smaller than my 21 and that was the overall diameter, so only 1/4" height wise.
Old Apr 14, 2011 | 03:27 PM
bikerlaw's Avatar
bikerlaw
In my opinion, if your doing that much two up then 12 inches should be the absolute LOWEST shock to run. Either choose a Heavy Duty 12 incher or have a set of custom jobs built for you. Plenty of people run 11's but to me thats way to harsh of a ride.
Old Apr 14, 2011 | 11:22 PM
HemiOrange's Avatar
HemiOrange
Originally Posted by Wyde Glyde Bry
I'm 220 and my wife is 150 as well..... I can't imagine going lower and having a quality ride. Lower is for looks. There's no way I could go lower than stock riding 2-up with packed saddle bags and tour pack unless my shocks were set to make it ride like a hay wagon.
I'm going to 13.5" shocks.
That will be a wise choice.
Old Apr 15, 2011 | 07:55 AM
rh8234's Avatar
rh8234
LOL that's hilarious..... getting a newer lighter wife can be an expensive mod though!!!
It was VERY expensive, but worth every cent! I should have gone with this mod many years ago.
robbyville
Oct 4, 2014 08:11 AM
burnsy87
Sep 7, 2014 08:58 AM
miketedesco
Dec 24, 2009 06:46 PM
WARG
Jun 9, 2008 09:27 PM
kbwideglide
Feb 22, 2005 09:31 PM
