so it starts... got the fairing in
head unit: Kenwood KIV-BT900
Amp: Massive-Audio NX2
6x9: Polk Audio DB691
3.5: Polk Audio DB351
also ordered some locking clamps, dont want over a G in stereo crap just to be unclipped and walk away!
but here are some pics
figuring out the spacing off the lamp
shot from the inside you can see it barely clears my risers
using stock quick release clamps (2 will be replaced with locking clamps and yes stainless bolts will be used not the stock ones)
used fender washers and plastic spacer to figure out the spacing... now we can machine a filler plate and weld that to the main bracker for support
after rebending, cutting, grinding, and sanding the support brackets
mounted
you can see my lamp really fills that cove
inside will be a kenwood 3.5 video screen, full range polk 6x9, massive NX2 amp, i pod dock station with video link, blue tooth for cell, GPS, and a ciggy lighter (3.5 polk 2 ways going in the bag lids)
what it looks like with someone behind the bars...
Which Batwing from Reckless did you go with?
That thing is going to rock, you'll be able to do some good touring and jam out at the same time!!! You should flush mount some LED turn sigs.
Good work ... keep all the measurements and source it ... you'll have guys on the forum lining up to buy a kit from you ....
R/
'Chop
If I decide to go this way.......which is very likely next winter.........i will be interested!!!!!
