error code P0131
Old Jun 1, 2011 | 11:20 AM
stilup's Avatar
stilup
Default error code P0131
Hey all, my bike just shut down at slow speed this morning and
at work got a P0131 code.
I was able to restart right away but shutting down in trafic is not good.
Any Ideas?
Old Jun 1, 2011 | 11:24 AM
yellowpearlfb's Avatar
yellowpearlfb
Hi...take a look and see if any of this information helps you.
https://www.hdforums.com/forum/softa...le-causes.html
Old Jun 1, 2011 | 12:25 PM
blueangel73's Avatar
blueangel73
Front Oxygen Sensor Low
Old Jun 1, 2011 | 12:43 PM
robertj74's Avatar
robertj74
That code possibly has been set by your Xied's,probally not related.
You may want to check your system relay inside your electrical center,it's either gray or black-can't remember which,the other one is the starter relay.
My bike was stalling and dying too, and after a couple of rounds with the dealer(still under warranty at the time) I had to track it down and fix it myself.
I actually pulled the relay apart and it was full of green corrosion.Installed a new one and never another problem.
Check it out you may have the same thing going on.
Old Jun 1, 2011 | 04:23 PM
stilup's Avatar
stilup
Made it home OK, didn't need to get stuck in a tornado, not far away. Springfield Ma. on the river. hailed.
well after reading this I am going to check for exaust leaks, check the system relay.
I cleared the codes before I left for home.
I might add that the other day I pushed the bike hard and the day after it started.
Old Jun 1, 2011 | 04:43 PM
RAWHIDE07's Avatar
RAWHIDE07
I've been running xieds for two years,po131/151 has always shown up in the codes(front&rear sensor low/lean)this is very common,the bike runs perfectly.Don't forget to check your battery cables and make sure they are tight.
Old Jun 1, 2011 | 08:07 PM
stilup's Avatar
stilup
OK thanks for the imput on the Xieds, I thought they had them code errors straightened out.
I had new spare relays so I changed them anyway. Tightend the exaust at heads at bit.
The thing that bothered me is my bike had shut down briefly but I was able to just restart it.
Well after a little ride tonight the bike is fine.
Thanks for your help.
III
15
Jul 24, 2016 02:19 PM
murmax21
Feb 18, 2016 10:19 PM
roundman327
Jun 15, 2012 12:42 AM
kmm4444
Sep 1, 2010 07:56 AM
AZCFH
Mar 15, 2010 01:21 PM
