"Do It Yourself" of the day
Old Nov 2, 2006 | 07:18 PM
RudeDog's Avatar
RudeDog
Default "Do It Yourself" of the day
There's a discussion going on over at the new Classic Evo forum about base gasket leaks and how to cure them. I posted a simple fix for this common problem and thought I'd share it with my buds over here also:
Go to the automotive store and pick up some Permatex flowable silicone windshield & glass sealer. The # on my tube is 65AR. Clean and dry surfaces to be sealed, apply glass sealer onto leak source, remove excess, let cure for 24 hours.
I used this product/method on my '91 FXRP and had no leaks after. Supposedly the glass sealer seeps it's way into the effected area sealing from the outside all the way to the inside and because it's silicone it can withstand the temperature of the motor.
There's your "Do It Yourself" of the day.
Old Nov 2, 2006 | 07:35 PM
phreak's Avatar
phreak
Default RE: "Do It Yourself" of the day
Great tip Rude! Thanks.
Old Nov 3, 2006 | 08:03 PM
RudeDog's Avatar
RudeDog
Your welcome. I am kind of surprised there are no other responses to this thread? Correct me if I'm wrong, but, I think most peoples bikes in this area are too new to have to worry about having a leak.
Old Nov 3, 2006 | 08:18 PM
brian1's Avatar
brian1
The newer bikes (twin cams) use an o ring to seal that area instead of that leaky paper
gasket that the evo's had all the problems with.
Old Nov 3, 2006 | 08:20 PM
Rhode Warrior's Avatar
Rhode Warrior
No leaks yet here, but a good tip for the future. Thanks.
Old Nov 3, 2006 | 08:21 PM
blueglide88's Avatar
blueglide88
You put silicone on your cylinder base gaskets?
Hmmmmm....next time my 1988 FLHS with 165,000 miles springs a leak, maybe I'll give it a try.
Old Nov 3, 2006 | 08:36 PM
lblax's Avatar
lblax
the only motor leak i have is in the front where the two main cases come together i might try it there
Old Nov 3, 2006 | 08:54 PM
RudeDog's Avatar
RudeDog
Ahhh there's some replies.
blueglide88 Date 11/3/2006 5:21:00 PM
Yes Blueglide, apply the windshield silicone to the seam, you don't have to gob it on, just apply it sparingly. This stuff works great because it seeps into the area providing a seal inistead of just covering the leak like normal silicone does. It is virtually invisible because it's clear and you don't need much to make a good seal.
Old Oct 11, 2007 | 06:38 PM
wjl24's Avatar
wjl24
Rudedog if that works I'm gonna be a real happy man. My bike runs absolutely perfect. It's a shame to have to tear it down for this little pesky leak. Cause you know if you tear it down your gonna do some extra stuff while in there. I'm going to give it a try this weekend.
bparsel
EVO
27
May 6, 2021 06:01 AM
Harleypilot63
EVO
Jul 3, 2017 04:03 PM
fame2
EVO
May 16, 2014 10:55 PM
AnyRoad
May 4, 2009 07:03 PM
BiggestDawg
Feb 25, 2008 04:41 PM
