engine mounts
Old Aug 5, 2011 | 02:30 PM
Flint's Avatar
Flint
5th Gear
Default engine mounts
What is the best way to tell if the rear and front engine mounts are still good or going bad?
Old Aug 6, 2011 | 09:34 AM
JRK5892's Avatar
JRK5892
you can typically look at the front and tell if it is shot, push on the motor if it moves the front is shot. really the only way to check the rear is either a bump it will feel like the motor moves when your rear tire goes over or when your motor is out if your trans moves around.
Old Aug 6, 2011 | 01:42 PM
nevil's Avatar
nevil
If the front one is really bad it will make a clank going over a bump, might even hit the front pipe on the frame downtube.
Old Aug 6, 2011 | 01:58 PM
PoCoBob's Avatar
PoCoBob
I've been told that if the rear one is bad the rear tire won't stay vertical if you lift the bike. It will tilt slightly. Don't know if that is true but it was a dealership that told me that.
Old Aug 6, 2011 | 03:52 PM
JRK5892's Avatar
JRK5892
blaster not sure hwo that is possible with the axel going though the wheel, the swing arm is not part of the mount, sounds like some dealership BS but i have been wrong before.,.. was a tuesday, ill never forget
Old Aug 6, 2011 | 06:51 PM
PoCoBob's Avatar
PoCoBob
The swing arm attaches to the rear of the tranny. The tranny is supported by the mount.
paulvs
Nov 8, 2017 06:54 PM
Trucker73
EVO
Dec 5, 2011 02:15 PM
skyntback
Sep 4, 2009 08:03 AM
malcolm06WG
Nov 13, 2006 10:54 PM
Stretchman
Apr 11, 2006 02:44 PM
