Still searching for problem
Old Aug 8, 2011 | 10:43 AM
stbobshadow's Avatar
stbobshadow
Default Still searching for problem
I've got the cutting out problem and checked many things . Checked the fuel line in the tank the loose ground and now the fuel injector wires . Well i get to the front injector wires and i see a few places the the ty wraps had pulled very tight and the wire appeared to be broken but after further inspection it wasn't and the connector appeared to be plugged all the way in . Anyone think that with the wire pulled so tight against the connector that it could cause this intermittent problem?
Old Aug 8, 2011 | 01:07 PM
lo-rider's Avatar
lo-rider
Thoroughly check all the mods that have been made.
Old Aug 8, 2011 | 01:21 PM
SC-Longhair's Avatar
SC-Longhair
Your bike is just cutting out while riding? If so, I'd suggest checking your ignition switch. I had that happen doing 65mph through the country and my bike cut out twice usually after hitting medium sized bumps/potholes. Rode to the dealer (it was on my way to my destination) and they verified the contacts on the switch were corroded. They cleaned the terminals and replaced the wires. No problems since.
I'd also look at your battery terminals as they may be loose.
Old Aug 8, 2011 | 01:27 PM
nevil's Avatar
nevil
Look at the ground cable where it's attached to the frame.
Old Aug 8, 2011 | 02:40 PM
stbobshadow
it only does it at low speed excelleration and sounds like its gasping for air.
Old Aug 8, 2011 | 03:42 PM
dynabobster's Avatar
dynabobster
What year and model? Check Engine Light and/or codes? Low speed acceleration, cruising?
Old Aug 8, 2011 | 06:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If the wires are pulled too tight at the injectors the little wire strands in the plugs could be breaking. On all the electricals we put on our boats we try to leave whats called a "service loop" and avoid "banjo tight" wire connections.
Old Aug 8, 2011 | 07:34 PM
stbobshadow
It's an 06 st bob and the wires to the front injector were banjo tight so i added a little slack while i had everything apart
bsb1970
May 4, 2018 09:05 AM
Jdog44
Apr 17, 2018 09:38 PM
kd4tsc
Sep 3, 2009 03:42 PM
madmarti
Mar 7, 2009 06:16 PM
wactc88
Mar 18, 2008 10:14 AM
