Battery question
Old Aug 8, 2011 | 10:14 PM
Comingapart's Avatar
Comingapart
Default Battery question
The stock battery in my '10 FXD is not holding a charge and has left me stranded twice.
My question is, is it normal for a battery to only last a year and a half?
I ride year round, so it's never set up for an extended period of time. I ride it almost everyday. I don't use a maintenance or trickle charger. Connections are clean and tight.
I've checked and there isn't any draw on the battery with the key off and it's putting 14-15 volts into the battery at idle.
I'm shopping for a replacement now, but since it seems odd that the battery would fail in less than two years, I want to make sure there isn't anything else I should check for so I don't have the same problem with the new batt.
Also, are the JP Cycles brand "High Output" batteries any good, or should I go with another choice?
Old Aug 8, 2011 | 10:22 PM
Spanners39's Avatar
Spanners39
18 months life is not unusual but if you getting 14-15 at idle I would get your regulator checked as 12.9-13.5 is more the correct figure....it may be cooked from over charging.
There are only two batteries you should fit in a Harley in my opinion, one is the genuine H-D brand and the other is Motobatt.
Old Aug 8, 2011 | 10:45 PM
thedonthere's Avatar
thedonthere
I just replaced my original battery 3 months ago. The original lasted 5 years. I religiously use a battery tender.
Old Aug 8, 2011 | 10:52 PM
DonN's Avatar
DonN
My first battery was bad from the start. Lasted 1 month and dealer replaced. My second lasted about 2 years. Heat kills them. I am trying a different brand this time.
Old Aug 8, 2011 | 11:03 PM
WS6 Formula's Avatar
WS6 Formula
My original Harley Davidson battery crapped out within six months, and was covered under warranty. After five years I replaced that one with a Deka East Penn battery http://www.dekabatteries.com/ , they make the Harley Davidson battery's
I also have my bike plugged into a Battery Tender when ever I'm not riding, made a big difference on my last bike for extending battery life.
Info below is from other threads:
Originally Posted by NEONNIGHT34609
woke up this morning and wanted to go for a ride but my Odyssey battery has sh** the bed. even know i got about 3 years out of it i dont feel it was worth the extra money. what are my other options? also it is better to order on line or should i look for something local. thanks
I would order online, it would be cheaper and they probably sell a lot more of them then a local shop, which would most likely get you a fresher battery then one that has been sitting on a shelf for who knows how long. Some quotes from other threads that should help.
Originally Posted by KBFXDLI
My guess: Remove your battery & load test it. Then make sure it is fully charged and reinstall making sure the cables are tight. I would get a 12v deltran battery tender from amazon for $27 if you are not using a tender. When batteries start to die the engine will hard start as they lose their ability to handle the load on startup.
If you need a new battery go to the East Penn Deka website as they make all of the Moco batteries. Call them to find a local distributor and you will save $30 over the dealer cost. If the battery takes a good charge and runs down again then test your stator & vr for charging voltage.
Originally Posted by pascoz28
Just thought I'd pass on a great deal I found on DEKA batteries...it's at Parkerbattery.com...the EXT20L (what I just bought for my 00 WG) was only $69 with FREE UPS shipping and if you use Paypal it's another 10% off, so I paid $62.10 shipped. I have no connection with Parkerbattery.com whatsoever...just thought this was a great deal and wanted to pass it on.
Here's the link: http://www.parkerbattery.com/ETX20L.html
Originally Posted by WS6 Formula
Run wires directly to the battery (use Loc-Tite). To make a quick connect / disconnect you can solder wires to a banana jack and mount it some were out of sight. Use an additional banana jack on the Battery Tender leads.
FRYS.com #: 2379099: http://www.frys.com/product/2379099
Pomona MDP-02 Double Banana Plugs w/ wire Guide. Set Screw Secure Leads, 5000-V DC, 15-A
  • Set screws secure wire
  • Accepts cables up to .215" max.
  • Contains one black and one red dual banana plug
  • Rating 5000V, 15 Amps
$4.99
Old Aug 9, 2011 | 01:12 PM
nevil's Avatar
nevil
My original battery lasted 23 months so it got replaced under warranty. They also checked the charging system when they did it. You hopefully still have some warranty left, right?
Old Aug 9, 2011 | 01:24 PM
flyscoal77's Avatar
flyscoal77
Yup over 14 Volts is suspect. I would install a trickle charger and see if that fixes the problem. If not get one of these:
http://www.powersports.braillebatter...tteries/b2015/
If this thing craps out then you know you have a different problem. These braille batteries kick ***. This is the same battery I'm using on my TP124 with 10:1 compression with no comp releases. Will fit your dyna battery box.
Old Aug 9, 2011 | 01:27 PM
KevenW's Avatar
KevenW
Sat.mine started acting like it was weak. Hope it's not the starter! Gonna take it and load test it. It'll turn over some and backfire sometimes and stop turning over so I let off.often have to do it a few times.sound like batt or starter?
FurryOne
Electrical/Lighting/Alarm
Jan 24, 2020 07:33 PM
fRESH88
Oct 23, 2019 03:51 PM
Derf_
Apr 20, 2017 06:41 PM
notofthisworld
Dec 5, 2014 11:19 PM
Ragnar Danneskjöld
May 30, 2012 05:21 PM
