Bike is dead?
Old Aug 16, 2011 | 10:56 PM
  #31
baxter's Avatar
baxter
Originally Posted by LarryLives
If it ran, then you swapped bars and now it wont start, it has to be a control wire, check your housings and start switch 1st and go from there.
Maybe if hits the horn it'll fire right up. Haha
Old Aug 17, 2011 | 05:02 AM
  #32
Frank ZX's Avatar
Frank ZX
I would defiantly cut those connectors out of the harness and soldier the connections.
Nice write up on wire soldiering.
Old Sep 21, 2011 | 09:39 AM
  #33
lkohan7373's Avatar
lkohan7373
Can't beat the old solder method. I have used the solder seals myself. (I own a business that does work on police cars). We found a problem with those is if the connection heats up the solder can become soft and the connection lost. Remember you are using a heat gun for this so those solder seals don't need as much heat as traditional solder to melt. Just an FYI for those that use them.
rich56
Electrical/Lighting/Alarm
21
May 11, 2020 07:14 AM
cycle7447
2014-2024 Touring Models
59
Oct 13, 2017 11:52 AM
HighonHarley
Aug 21, 2015 02:29 PM
ibmikexxx
Jun 15, 2015 07:27 PM
mrbuck
May 6, 2008 06:05 PM
