XiED's on the way!
Old Oct 14, 2011 | 02:26 PM
  #41
spaceblue's Avatar
spaceblue
Originally Posted by bsljacques
Well got them in the mail Friday and installed them Sunday morning...but it rained all day long.....so maybe a chance to ride today...if the weather clears up. All in all it was a 10min job. I went ahead and on the front cylinder I removed the front plastic deal that holds the connections and drilled 2 small holes in it to zip tie the new connector. I like it to look clean. Looking forward to the ride and I will report back with results.
I also would be interested in any mileage change you get. Some have reported better, some worse. I have stated before (garnering much flack for it) that I'm not a fan of Xieds because of the fixed signal they send to the ecm, negating its ability to adjust. Still I'm hoping to learn from any real world data on the subject.
Old Oct 14, 2011 | 02:51 PM
  #42
TopKat's Avatar
TopKat
All good info so far. We need to keep this thread going so more guys can chime in with their results. For around $100 this seems like the best "bang for the buck" but I too am still a little sceptical. I for one love the MPG I'm getting and dont want to sacrifice any of that. Their website also mentions a couple of fault codes that may pop up but not to worry. It's always something.
Old Oct 14, 2011 | 03:32 PM
  #43
rooti's Avatar
rooti
I'm not an expert, but I believe your wrong on that. XEID's are nothing more then a resistor to trick your ECM into thinking its not giving enough fuel. The ECM should still adjust exactly like it always has except it will be giving out more fuel.
I have never got a fault code. The code they talk about many get without doing anything. Harley has a service bulletin to ignore the code.
Old Oct 14, 2011 | 03:54 PM
  #44
spaceblue's Avatar
spaceblue
Well I may be, if that is true. It is my belief that the Xieds fix the AFR at a set % and that is the end of it. If what you're saying is true the set point is changed and the adjustment of the system remains intact. So which of us is correct? Anyone else with a thought on this?
Just as an aside to all this I have gone off on a reading tangent on the EFI tuner subject and found this; https://www.hdforums.com/forum/tourin...rpro-test.html
Very interesting indeed. Again my problem with Xieds was a perceived (on my part) lack of sophistication and my problem (fear?)with tuners is that any attempt on my part at rocket science will eventually end up as a screw up.
Old Oct 14, 2011 | 07:52 PM
  #45
rooti's Avatar
rooti
That's why I like the XEID's, because everything works exactly the same except you get more fuel. I am leary about a tuner that I would have to disconnect my O2 sensors. The XEID's go between the O2 sensor and the EFI and like I said they are nothing more then a simple resistor.
Old Oct 14, 2011 | 10:19 PM
  #46
LDB187's Avatar
LDB187
Ok, I've been reading all this and think I'll give'm a try. I would like to put some on my 07 1200L and a 2012 FLD. What is the web site for these?
Old Oct 15, 2011 | 08:23 AM
  #47
TopKat2's Avatar
TopKat2
Stage II
Here ya go:
http://www.nightrider.com/parts/
silverbullitt
Sep 19, 2011 05:58 AM
441amx
Aug 18, 2011 07:27 AM
Overdose
Jul 24, 2011 12:15 AM
MADDOG187
Exhaust System Topics
May 24, 2011 08:50 AM
MissingLink33
Sep 14, 2010 08:18 PM
