Dyna Swingarm Bag / 90200570
Old Oct 25, 2011 | 12:52 PM
LoveHate's Avatar
LoveHate
Default Dyna Swingarm Bag / 90200570
Hello guys.
Has anyone seen this bag closely. I can not find pictures of the back /how to install and what exactly is fixed/
Thanks in advance for any response.
Old Oct 25, 2011 | 01:06 PM
Wide Glide Gabes's Avatar
Wide Glide Gabes
I really like that bag. Too bad that it takes the place of the passenger foot pegs.
Old Oct 25, 2011 | 01:23 PM
LoveHate's Avatar
LoveHate
...this is not a problem for me, my bike is definitely solo...
Old Oct 25, 2011 | 01:42 PM
Gringoloco13's Avatar
Gringoloco13
I have it installed on my bike, nice bag. The way it mounts are brackets that bolt to the frame where the passenger peg was. Then you run straps through the slots in the back of the bag (they are a lock down strap with a plastic lock fold over type). The bag itself is leather and it has a hard reinforced plastic liner on the back side of the bag to keep it straight (the plastic is inside the bag). The front looks like standard belt buckle style straps but underneath are quick connect plastic locks.
Yep reading owned me on that one, I bought it not paying attention to that note. So when I went to install it the directions stated to remove the passenger peg. The wife rides with me so that wasn't an option and I really like the bag so I didn't want to try to sell it. So I mounted it onto my battery cover and made it work, still looks good though.
Old Oct 25, 2011 | 02:19 PM
LoveHate's Avatar
LoveHate
Тhank you Gringoloco!
So the method of attachment is strong enough?
LoveHate's Avatar
LoveHate
Old Oct 25, 2011 | 02:32 PM
Gringoloco13
No problem and the method of attachment is def. strong enough once you tighten the straps down and lock them down. Mine isn't installed in the original spot but straps down the same way to my battery cover. No issues at all with it being not secured or coming off down the road.
Old Nov 7, 2011 | 09:26 AM
Rider83's Avatar
Rider83
Hi GringoLoco,
Can you put some pics on how it looks mounted on your bike.
Thanks, I also bought it without looking at the installation instructions so if I could avoid removing the footpegs it will be better.
Old Nov 7, 2011 | 03:04 PM
Gringoloco13
Originally Posted by Rider83
Hi GringoLoco,
Sure thing check out the attachment, I can provide more pics when I get my bike back from my painter. I am getting a custom paint job done right now and he has a couple projects ahead of mine. So it won't be until around Xmas time that I get the bike back.
Attached Thumbnails Dyna Swingarm Bag / 90200570-309167_10150288338489677_508219676_8134375_2078002384_n.jpg
Old Nov 7, 2011 | 03:33 PM
toastman's Avatar
toastman
could you use a longer set of bolts and mount the bag bracket underneath the pass. peg mount?
